Desktop / Taskbar problem
sahaigustavo Santos Hernandez 20 Reputation points
2026-03-21T15:18:02.9933333+00:00
I've recently been having a problem where constantly I can't click anything on my desktop, like windows or the taskbar. They don't even highlight. It's like, it's also not selecting the window, and sometimes it randomly click or just doesn't click anything. I've seen somewhere that pressing Ctrl + Alt + Del fixes it, and it does, but only for a second or two before it returns. Sometimes it goonesaway- See that?? it clicked randomly on the text box- anyways, sometimes it goes away on it's own, only to return. I've tried reinstalling updates, uninstalling updates, verifying the files with sfc /scannow, checking for viruses, even SAFE MODE didn't work, so this has to be something serious. And don't tell me to just reinstall windows, it has to be something. I doubt that it's something that I installed, it has to be something corrupted that for some reason isn't detected by the system. Just to clarify, I've tried EVERYTHING that AI has told me. Restarting explorer, reinstalling updates, safe mode, renaming keys with regedit, settings, everything. Some background information is that I recently had a trojan, but I purged that and there's no leftovers.
A possibility is that it's being caused by me pressing Ctrl + Alt + Del so much to temporarily fix it, but idk
Windows for home | Windows 11 | Desktop, Start, and personalization | Desktop
Lychee-Ng 27,955 Reputation points Microsoft External Staff Moderator
2026-03-23T14:31:53.43+00:00
Hi sahaigustavo Santos Hernandez,
I understand how frustrating it is to be when everything is not working, and it feels like Windows itself is falling apart. You’ve clearly gone far beyond basic troubleshooting already, so I will skip the generic advice and go for nuclear solutions instead, if you don't mind. Please try out the below:
1 - Use built-in repair option
  • Open Settings > System > Recovery > Fix problems using Windows Update
  • Click Reinstall now > follow the onscreen instructions to reinstall Windows.
Disclaimer: This reinstallation can fix update issues without removing your files or applications. However, we always recommend that if you have important data, you should back it up.
2 - Perform an in-place upgrade
Disclaimer: An in-place install or in-place upgrade will refresh your Windows files and operating system without removing files or applications. That being said, we always recommend that if you have important data, you should back it up before making large system changes.
3 - Reset PC from Recovery
  • Power on the PC > force shutdown during boot 3 times to trigger recovery
  • When in WinRE, choose Troubleshoot > Advanced options > Reset this PC
  • Choose Keep my files > Local reinstall > Confirm and let it complete
Disclaimer: This allows you to keep your files, but your applications and settings will be removed.
Unfortunately, if none helps, we might need to perform a clean install to get your PC back into a working condition. You can find instructions by navigating to the bottom of this guide: Reinstall Windows with the installation media - Microsoft Support. This solution will delete all your data so please ensure that you backup anything important, including Documents, Pictures, Videos, and more.
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
1 additional answer
    2026-03-21T15:18:17.75+00:00
    Based on the symptoms, this matches known Windows issues where the desktop, taskbar, and Start-related UI stop responding to mouse input while keyboard input still works, and sometimes recover briefly after Ctrl+Alt+Delete.
    Try these concrete checks and workarounds:
    1. Restart Windows Explorer
      1. Press Ctrl + Shift + Esc to open Task Manager.
      2. Go to the Processes tab.
      3. Find Windows Explorer.
      4. Right‑click Windows Explorer and select Restart.
      This directly targets the shell (desktop, taskbar, Start) which is often the component that hangs.
    2. Sign out and sign back in
      1. Press the Windows logo key (if it still responds) or use Ctrl + Alt + Delete and choose Sign out.
      2. Sign back into the account.
    3. Check for corner/navigation behavior (if upgraded from Windows 8.1 or similar behavior) On systems where dragging to screen corners or using certain shell gestures is involved, UI elements like Start, charms, and app controls can stop responding. The documented workaround is to disable the corner navigation feature:
      1. Open Settings.
      2. Go to PC and DevicesCorners and edges (on older builds that still expose these options).
      3. Under Corner navigation, turn off “When I click the upper-left corner, switch between my recent apps”.
    4. Check for taskbar focus issues If the taskbar or another window is forced on top, clicks on other windows may not switch focus correctly. For classic “Always on top” issues:
      1. Use Alt + Tab to switch to another program.
      2. Open Taskbar & Start Menu settings.
      3. Ensure the taskbar options are configured correctly so it is not being obscured or locked behind full‑screen apps.
    5. If the desktop becomes unresponsive after display off/on On some Windows builds, when the display turns off and then resumes, the desktop can stop responding to mouse and keyboard for a period of time due to Desktop Window Manager (DWM) behavior. Workarounds include:
      • Turn off Auto‑hide the taskbar in Taskbar and Start Menu settings.
      • Avoid turning off the display automatically in Power Options, or increase the timeout.
      • Keep at least one window open on the desktop instead of minimizing/closing all windows.
    If these steps stabilize the desktop and taskbar, the root cause is likely in the shell (Windows Explorer / DWM / taskbar behavior) rather than hardware or malware, even if SFC and virus scans show clean results.
