Vs code not working properly
M. Zubair 0 Reputation points
2026-03-20T19:09:55.5966667+00:00
prelaunchtask c c++ g ++ exe build active file terminated on vs code
this error wasted my whole day tried to resolve it thourgh all possible way resintalled vs code and C++ complier added the path but no help .
Kindly resolve my issue.
Developer technologies | C++
A high-level, general-purpose programming language, created as an extension of the C programming language, that has object-oriented, generic, and functional features in addition to facilities for low-level memory manipulation.
    2026-03-20T19:10:18.69+00:00
    The error indicates that the build task VS Code runs before debugging (“preLaunchTask”) is failing, so the C++ program never compiles or starts. In Visual Studio and MSBuild, similar symptoms appear as task-executable errors like MSB6003 or PRJ0003 when the compiler tool cannot be run.
    Check these points step by step:
    1. Verify the compiler can run from a terminal
      1. In VS Code, open Terminal → New Terminal.
      2. Run the compiler command that the task uses (for example g++ --version or cl if using MSVC).
      3. If the command is not recognized, the compiler is not on the PATH or not installed correctly. Fix the compiler installation and PATH first.
    2. Check the build task configuration in VS Code
      1. Open .vscode/tasks.json in the workspace.
      2. Find the task whose label matches the preLaunchTask name in .vscode/launch.json.
      3. Confirm:
        • command points to the correct compiler executable.
        • Any paths in args (for source or output files) are valid.
      4. If the path to the compiler is wrong or the executable is missing, update it.
    3. Look at the full error output
      1. Run Terminal → Run Build Task… and choose the C/C++ build task.
      2. Read the full output in the terminal. Errors like “executable could not be run”, “file not found”, or similar match the MSB6003 description where the task executable cannot execute.
    4. Check for system issues that can block the tool Similar to Visual Studio errors PRJ0003 and MSB6003, the build can fail if:
      • The compiler executable file is missing or the path is incorrect.
      • A required file in the build folder is locked by another process.
      • There are too many temporary files in the build folder.
      • The path to the output or source file is extremely long.
      Clean the build/output folder and try again. If antivirus or other tools may lock files, temporarily disable them and retest.
    5. If using MSVC toolset from Visual Studio
      • Ensure the Desktop development with C++ workload is installed in Visual Studio.
      • Confirm the MSVC tools (like cl.exe) are available and their paths are correctly referenced in VS Code tasks.
    Once the build task runs successfully from Run Build Task…, the preLaunchTask will complete and debugging should start normally.
