A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
The context only provides general guidance on using the laser pointer and improving media performance in PowerPoint, not a specific fix for lag with the laser pointer/pen during recording on macOS Tahoe.
From the available information, only general performance-improvement steps can be suggested:
- Reduce media and effects load in the presentation
- Compress embedded audio/video in the deck to reduce processing overhead: use the media compression guidance in PowerPoint to decrease presentation size and improve playback performance.
- Limit special effects on media (shadows, reflections, glow, soft edges, bevels, 3‑D rotation) as these can negatively affect playback and responsiveness during recording and export.
- Adjust how the pointer is used during slide show
- Ensure the pointer mode is set appropriately (Automatic/Hidden/Arrow/Pen) so PowerPoint is not frequently switching modes, which can add overhead.
- On macOS in Slide Show mode, use the Pen/Laser Pointer tools from the helper buttons in the lower-left corner and keep to a single tool (Laser Pointer or Pen) rather than switching repeatedly while recording.
- Re-test with a simpler presentation
- Create a new, minimal presentation (few slides, no or very small media, no heavy effects) and record while using the laser pointer/pen. If lag is reduced, the issue is likely related to media size/effects and can be mitigated by simplifying or compressing content as above.
If the lag persists even with a very simple presentation and after reducing media/effects, the context does not provide further macOS/Tahoe-specific troubleshooting steps or known issues for this scenario.
