Loud static coming through bluetooth headphones on MS Teams
Kaden Pitcher 75 Reputation points
2026-03-18T23:08:26.3466667+00:00
I was using my Bluetooth headphones with my computer and music, videos, and system sounds were coming through just fine on my headphones, and then I jumped onto a Teams call, and there was so much static I couldn't hear a thing. When I changed to wired earbuds, the sound was fine. These headphones were fine with Teams before, and they're still currently fine with everything else.
Microsoft Teams | Microsoft Teams for education | Meetings and calls | Audio and video
    2026-03-18T23:08:40.4833333+00:00
    Static only in Teams while Bluetooth audio works elsewhere usually means a Teams- or Windows-audio configuration issue rather than a hardware fault.
    Try these steps in order:
    1. Verify the correct speaker in Teams
      1. In Teams, select Settings and more (⋯) > Settings.
      2. Select Devices.
      3. Under Audio > Audio settings, make sure your Bluetooth headphones are selected in the Speaker dropdown.
      4. If they don’t appear, make sure they’re charged and connected in Windows, then reopen Teams and check again.
      5. Select Make a test call and listen for static. If the test call is clear, the issue may be with that specific meeting or other participants’ microphones.
    2. Check speaker during the meeting
      1. In the meeting window, select the dropdown arrow next to Mic.
      2. Select More actions > Audio settings.
      3. Under Speaker, confirm your Bluetooth device is selected and not muted.
      4. If the device is listed but audio is distorted, switch briefly to another speaker, then back to the Bluetooth device to force Teams to reinitialize the audio path.
    3. Confirm Windows sound format and device
      1. In Windows, select Start > Settings > System > Sound.
      2. Under Output, select your Bluetooth headphones.
      3. In Output settings, under Format, ensure a standard format such as 2 channels, 16 bit, 48000 Hz (DVD Quality) is selected. Nonstandard or low-quality formats can cause distortion with some apps.
    4. Re-pair the Bluetooth headphones
      1. Select Start > Settings > Bluetooth & devices > Devices.
      2. Under Audio, select your headphones, choose Disconnect, then Remove device.
      3. Put the headphones into pairing mode per the manufacturer’s instructions.
      4. Select Add device > Bluetooth, then select the headphones when they appear.
      5. Join a Teams meeting again and test.
    5. Update Windows and Teams
      1. Install the latest Windows updates.
      2. Make sure the latest version of Teams is installed, then restart Teams and test again.
    If static persists only with this one Bluetooth device and Teams, but not with other Bluetooth headsets or speakers, the headset may have a compatibility issue or be starting to fail. Testing with another Bluetooth device can help confirm this.
