Open Settings > Apps > Installed Apps > System Components, find "Get Help," tap the "Advanced" option on the right, and try Repair first. If that doesn't work, try Reset.
See if this resolves the issue.
Why do I get only an blank page when I try to open Get Help app?
AI answer
A blank page in the Get Help app usually means the app is opening but not loading its content or troubleshooters correctly.
First, try opening Get Help in all the supported ways to confirm the app itself launches properly:
Or, from Settings:
If the window opens but stays blank, use these steps to narrow down the issue:
If Get Help remains blank even though the device is online and signed in, use the web support entry point instead of the app:
For accessibility scenarios (for example, using a screen reader), Get Help should still present a searchable interface. If it is blank with a screen reader as well, use the Microsoft Support website directly instead of the app.
