Microsoft Graph returns 422 when using $expand=children on a file driveItem
Nguyễn Liễu 10 Reputation points
2026-03-17T10:08:50.12+00:00
I call the API GET https://graph.microsoft.com/v1.0/drives/{drive-id}/items/{driveItem-id}?$expand=children where the driveItem-id belongs to a file.
Yesterday the request worked normally, but today it returns a 422 error as shown below.
    "error": {
        "code": "notSupported",
        "message": "Children cannot be listed from an item that is not a folder",
        "innerError": {
            "code": "unprocessableEntity",
            "innerError": {
                "code": "getChildrenOnNonFolder"
            "date": "2026-03-17T08:46:29",
            "request-id": "83a946e0-784c-469e-8cc0-c881ba0cfb3c",
            "client-request-id": "83e7345c-0746-e5bd-e718-73c2be348f9c"
Microsoft Security | Microsoft Graph
    2026-03-17T10:09:06.8533333+00:00
    The 422 response and the message Children cannot be listed from an item that is not a folder are expected when using $expand=children on a driveItem that represents a file rather than a folder.
    The OneDrive/Graph driveItem model only exposes a children relationship for items that have a non-null folder (or package) facet. Files do not have children, so attempting to expand or list children on a file now correctly returns an error instead of silently succeeding.
    To fix the issue:
    1. Ensure that $expand=children is used only when the target driveItem is a folder (or package):
      • First get the item metadata without expand:
             GET /drives/{drive-id}/items/{item-id}
      • Check that the response has a non-null folder facet before calling with $expand=children or before calling /children.
    2. For folders, use one of the supported patterns:
      • Get folder metadata and children in one call using $expand=children:
             GET /drives/{drive-id}/items/{folder-item-id}?$expand=children
        (Only valid if the item is a folder.)
      • Or list children directly:
             GET /drives/{drive-id}/items/{folder-item-id}/children
    3. For files, remove $expand=children entirely, because files cannot have children. Use a simple GET:
         GET /drives/{drive-id}/items/{file-item-id}
    If this previously “worked” on a file driveItem, the behavior was likely permissive or inconsistent and has since been corrected to enforce the documented rule that only folder/package items can have children.
