The below Script works perfectly
SteveD 625 Reputation points
2026-03-17T01:15:45.55+00:00
At this time the below will put "8085" ARUNDEL CASTLE in the left column
I have a lot that have X8085 ARUNDEL CASTLE
Can the below please be modified to also include X at the beginning of the numerals.
Sub CopyNumbersOnly()
Dim cell As Range, num As String, ch As String, i As Long
For Each cell In Selection
    num = ""
    For i = 1 To Len(cell.Value)
        ch = Mid(cell.Value, i, 1)
        If IsNumeric(ch) And ch <> " " Then
            num = num & ch
        End If
    Next i
    cell.Offset(0, -1).Value = num ' Puts result in next column
Next cell
```End Sub
Developer technologies | Visual Basic for Applications
    2026-03-17T01:15:54.5966667+00:00
    Modify the code so it optionally prefixes an "X" when any digits are found. For example:
            num = ""
                    num = num & ch
                End If
            Next i
            ' If any digits were found, prefix with X
            If num <> "" Then
                num = "X" & num
            End If
        Next cell
    End Sub
    This will turn:
    • 8085 ARUNDEL CASTLE into X8085
    • X8085 ARUNDEL CASTLE also into X8085 (the original X is ignored; the new one is added before the digits).
    If the prefix should only be added when the original text already starts with X, add a test on the cell value instead:
    If num <> "" Then
        If Left(cell.Value, 1) = "X" Then
            num = "X" & num
        End If
    End If
