How to enable searching/recognition of handwritten notes on onenote iPad?
Joey Choong 5 Reputation points
2026-03-16T03:18:39.07+00:00
I am recently bought a new ipad air (2026, M4) and am writing handwritten notes on onenote, but one note cannot recognise any handwritten words when I search. I also tried searching the words I wrote on my iPad using a windows PC ( I heard the ORC is better on windows) but it still does not recognize the handwritten words. This feature worked when I was writing with a surface pro, but it is not working on my iPad. However I have seen people on youtube getting it to work. I have tried lasso-ing the ink -> right click -> treat ink as handwritting and it does work, but I do not want to lasso tool every single word as it will become a big hassle.
I want to keep my notes as handwriting (I do not want to convert it to text).
I am wondering if there is a way to fix this so I can search up handwritten notes written from my iPad. Or if there is a way to automatically make all ink be treated as hand writing?
Thanks!
Microsoft 365 and Office | OneNote | For education | iOS
  1. Debashmita Saha 235 Reputation points
    2026-03-16T03:54:18.5266667+00:00
    Hi Joey.
    Thanks for the question. On OneNote for iPad, the ability to search handwritten notes depends on ink recognition (OCR), but unfortunately, it doesn’t work as seamlessly as it does on Windows or Surface devices. Here’s the situation based on what you’re seeing:
    • Handwriting search limitations on iPad: OneNote for iOS doesn’t automatically index handwritten ink for search the way the Windows desktop app does. That’s why your handwritten notes aren’t being recognized when you search, even though the same notes worked fine on your Surface Pro.
    • Workaround with “Treat Ink as Handwriting”: As you discovered, lassoing the ink and marking it as handwriting allows search to work—but it’s manual and impractical for large notes.
    • Cross-device search: Even if you sync your iPad notes to OneNote on Windows, the OCR engine often fails to recognize handwriting created on iPad. This is a known limitation.
    • Why YouTube demos look different: Some videos show handwriting search working, but usually those are either on Windows devices or using converted text rather than raw ink.
    At present, OneNote for iPad does not support automatic recognition and search of handwritten ink. The only options are:
    • Convert handwriting to text.
    • Manually mark ink as handwriting.
    • Use OneNote on Windows/Surface for better OCR support.
    Microsoft hasn’t yet enabled full handwriting search on iPad, so it’s not something you can “fix” with a setting—it’s a platform limitation rather than a bug. I am not aware of any roadmap update announcement to bring full handwriting search to OneNote but hopefully they have something when the demand and timing is right.
    Hope this was helpful!
  2. Sophie N 18,175 Reputation points Microsoft External Staff Moderator
    2026-03-16T04:47:35.1866667+00:00
    Dear @Joey Choong,
    I understand your goal is to keep your notes as raw handwriting while still being able to search them. However, based on the current design of OneNote for iPad, handwritten ink is not automatically indexed for search as it is on Windows or Surface devices.
    Currently, the system requires a manual trigger such as using the Lasso tool to "Treat ink as handwriting" or converting it to text for the OCR (Optical Character Recognition) engine to recognize the words. I understand that this is a significant hassle for a large volume of notes.
    Since this is a platform design rather than a technical error, I highly recommend sharing your experience directly with our product team. Your feedback is crucial in helping us prioritize this feature for future updates:
    1. In-app Feedback: In OneNote for iPad, go to Settings (gear icon) > Help & Feedback > Tell Us What Can Be Better.
    2. Microsoft Feedback Portal: You can also post this suggestion on the Microsoft Feedback Portal.
    By raising this feedback, you help the engineering team understand the demand for automated handwriting recognition on the iPad Air (M4) and other iOS devices.
    Please note that as community moderators, we cannot change product design, but we can guide you to the right channel, so your feedback reaches the engineering team.
    Thank you for helping us improve our products. Please let me know if there is anything else I can assist you with.
