Inquiry Regarding strict gpt-realtime Quota Limits and Scaling Options on Pay-As-You-Go
Adio Gion 0 Reputation points
2026-03-16T01:42:55.33+00:00
I am reaching out to discuss the current quota limits for the gpt-realtime model (GlobalStandard deployment) as outlined in your quota tier reference.
My team is currently building an AI voice agent platform designed to handle live phone calls on behalf of our users. Because these are real-time, concurrent voice interactions, our application requires substantial and reliable throughput. We heavily rely on the predictability and flexibility of the Pay-As-You-Go pricing model for this project and intend to stay on it.
In reviewing the quota tiers, I noticed that the limits for the gpt-realtime model are remarkably strict and unusually flat. Specifically, Tiers 1 through 5 are capped at exactly the same rate: 200 Requests Per Minute (RPM) and 100,000 Tokens Per Minute (TPM). Even at Tier 6, the limit only increases to 300 RPM and 150,000 TPM.
To be frank, this quota structure feels overly restrictive and disproportionate for a production-level application. With these current ceilings, we are highly concerned about hitting rate limits and bottlenecking our platform. We need to accurately provision our resources now to avoid any dropped calls, disruptions, or surprises once the project is deployed to production.
Could you please help us understand and navigate this issue by answering the following questions:
Why is the quota flattened? Could you explain why there is no increase in limits from Tier 1 all the way through Tier 5?
How can we increase our Pay-As-You-Go limits? What is the exact process to request a substantial quota increase for our subscription to support a high-volume production workload?
What is the maximum limit achievable? At what level or capacity can we realistically expect to provision this model on a Pay-As-You-Go basis once a quota increase is approved?
Are there alternative architectural workarounds? Since we want to remain strictly on Pay-As-You-Go, are there recommended strategies to bypass these limits? For example, are we permitted to deploy the model across multiple Azure regions and load-balance the traffic to increase our overall RPM/TPM?
We need to understand our provisioning capabilities accurately to ensure a smooth and reliable production launch for our users. I look forward to your guidance on how we can resolve this scaling bottleneck without shifting away from the Pay-As-You-Go model.
Thank you for your time and assistance.
Best regards,
    2026-03-16T01:43:22.2233333+00:00
    The gpt-realtime quotas and scaling options on Pay-As-You-Go can be summarized and addressed as follows, based only on the documented quota tier behavior.
    1. Why the quota appears flattened from Tier 1–5
    For the gpt-realtime model with GlobalStandard deployment, the quota tables show:
    • Tier 1: 200 RPM, 100,000 TPM
    • Tier 2: 200 RPM, 100,000 TPM
    • Tier 3: 200 RPM, 100,000 TPM
    • Tier 4: 200 RPM, 100,000 TPM
    • Tier 5: 200 RPM, 100,000 TPM
    • Tier 6: 300 RPM, 150,000 TPM
    The documentation does not provide a specific explanation for why this particular model’s RPM/TPM does not scale between tiers 1–5. It only states that:
    • Quota tiers are designed to “improve the Foundry Models experience and reduce friction as workloads scale.”
    • Automatic tier upgrades are “based primarily on customer consumption trends” and relationship with Microsoft (EA/MCA-E, payment history, etc.).
    So, for gpt-realtime, the published behavior is simply that the per-subscription quota is effectively capped at 200 RPM / 100k TPM for tiers 1–5 and only increases at tier 6.
    1. How to increase Pay-As-You-Go limits
    For Foundry Models (including Azure OpenAI in Foundry), quota can be increased in two ways:
      • As usage grows and the current tier becomes limiting, the system “automatically upgrades the customer to the next higher tier.”
      • Enterprise relationships (EA, MCA-E) and good payment history improve eligibility for automatic upgrades.
    • Manual quota increase requests
      • The documentation explicitly states: “Yes, using the quota request form you can always request more quota. If the request is approved, the current tier will remain the same, but with more quota assigned.”
      • This applies even if the table shows a given RPM/TPM for that tier; an approved request can assign higher custom quota than the default tier value.
    Process on Pay-As-You-Go:
    1. Use the quota request form referenced in the quotas and limits page.
    2. Provide subscription details, region, model (gpt-realtime, GlobalStandard), and the required RPM/TPM for production.
    3. If approved, the subscription remains in its current tier but with higher quotas than the default tier values.
    4. Maximum limit achievable on Pay-As-You-Go
    The documentation does not state a fixed maximum RPM/TPM for Pay-As-You-Go beyond the published tier tables. It only clarifies that:
    • Previously approved quota increases are retained and “will not be reduced.”
    • Additional quota can be requested via the quota form, and if approved, it is applied on top of the tier defaults.
    Therefore, the realistic maximum for a specific subscription and workload is determined case-by-case through the quota request process; no numeric upper bound is documented for gpt-realtime beyond the tier 6 defaults.
    1. Architectural workarounds while staying on Pay-As-You-Go
    The context provides general guidance for handling rate limits and scaling Azure OpenAI workloads on Pay-As-You-Go:
    • Combine multiple deployments / backends
      • For token-per-minute restrictions, the guidance is to “consider combining multiple Azure OpenAI deployments in an advanced architecture to build a system that delivers more tokens-per-minute to more users.”
      • This pattern can be applied by:
        • Creating multiple deployments of the same model (potentially across regions where supported), and
        • Using a gateway or load balancer to distribute traffic across them.
    • Load balancing and scaling
      • For high traffic, the recommendation is to “create a load balancer for your application,” with a sample for Azure API Management–based load balancing for pay-as-you-go.
      • This allows spreading requests across multiple Azure OpenAI resources/deployments to increase effective throughput.
    • Multi-region considerations
      • The documentation does not explicitly forbid using multiple regions for the same model to increase aggregate RPM/TPM, and the multi-backend guidance is framed as a supported pattern.
      • Any multi-region design must still respect data residency/compliance requirements and actual model availability per region.
    1. Additional operational notes
    • Auto-upgrade opt-out
      • Customers can opt out of automatic tier upgrades by setting a flag to NoAutoUpgrade, but this is intended for those using quota as a billing control and is not a best practice for scaling.
      • For a scaling-sensitive, production voice platform, leaving auto-upgrade enabled and combining it with explicit quota requests is more aligned with the documented guidance.
    • When to consider alternatives
      • The context suggests that when throughput requirements are “well defined, predictable,” switching to provisioned throughput (dedicated server) is recommended. However, since the requirement is to remain on Pay-As-You-Go, the supported path is:
        • Use tier auto-upgrades where possible,
        • Submit explicit quota increase requests for gpt-realtime,
        • Architect with multiple deployments and load balancing to aggregate capacity.
