Kinect v2 requires specific drivers and hardware support. If the Kinect software or driver download page is not working or the driver is missing, the only supported options from the available information are:
- Make sure Windows is fully updated
- On Windows 10:
- Select Start > Settings > Update & security > Windows Update.
- Select Check online for updates from Microsoft Update and install all available updates.
- On Windows 11:
- Select Start.
- Type settings, open Settings > Windows Update.
- Select Check for updates and install all available updates.
- On Windows 10:
- Reinstall or refresh the camera/USB drivers
Kinect v2 appears to Windows as a camera- and USB-based device. If it is detected but not working, reinstalling the related drivers can help:
- Open Device Manager (type device manager in the taskbar search and select it).
- Locate the Kinect-related entry under Cameras or Imaging devices (or any device with a warning icon that appears when Kinect is plugged in).
- Right-click the device and select Properties > Driver tab.
- Select Uninstall device and, if available, check Delete the driver software for this device, then select OK.
- In Device Manager, open the Action menu and select Scan for hardware changes so Windows reinstalls the driver.
- Restart the PC and test again.
- Switch to the in-box USB Video Class (UVC) driver if applicable
If Kinect v2 is exposed as a USB video device and the vendor driver is failing, switching to the standard Windows UVC driver may allow basic video functionality (note: advanced features may not work):
- Open Device Manager.
- Find the Kinect camera entry under Cameras or Imaging devices.
- Right-click it and select Update driver.
- Select Browse my computer for drivers.
- Select Let me pick from a list of available drivers on my computer.
- Choose USB Video Device and select Next.
- Close Device Manager and test the camera functionality.
- If the device still does not work
- Check the PC or motherboard manufacturer’s support site for updated USB/chipset and video drivers and install them, then reboot.
- If Kinect still is not detected or fails after driver reinstall, contact the Kinect hardware manufacturer or PC OEM for updated drivers or confirmation of support on the current Windows version.
