How do I stop Excel from highlighting two cells at once?
Steven Manning 0 Reputation points
2026-03-13T19:57:30.6933333+00:00
How do I stop Excel from highlighting two cells at once. I printed my spreadsheet and discovered that one cell printed as ################ instead of the dollar amount of the formula for that cell. I played around with it for some time and I still can't figure it out. I did notice that the adjacent has something to do with this problem.
How can I reset the cell in question, which has a formula, to resolve this problem?
Thanks in advance.
    2026-03-13T19:57:40.2233333+00:00
    Excel is behaving as expected in both cases, and both issues are easy to fix:
    1. Cell prints as ################
      • This is not a formula error. It means the column is too narrow to display the formatted value.
      • Fix:
        1. Widen the column by dragging the right edge of the column header, or
        2. Select the column and use Home > Format > AutoFit Column Width.
    2. Excel “highlighting two cells at once”
      • In many cases this is just Excel selecting a range because of how the mouse was dragged or because Shift/Ctrl was held.
      • To reset selection:
        1. Click once on a single cell (no dragging) so only that cell is selected.
        2. If multiple cells still select unexpectedly, press Esc to cancel any active selection, then click the cell again.
      • If the worksheet is protected, selection behavior can be restricted; unprotecting the sheet (if allowed) can restore normal selection.
    3. Reset the problem cell with the formula
      • After widening the column, the formula result should display correctly.
      • If the cell is still misbehaving (for example, formatted as Text):
        1. Select the cell.
        2. Change its format to a numeric format (e.g., Number or Currency) via Format Cells > Number.
        3. Press F2, then Enter to re‑enter the formula so Excel recalculates and displays the value.
