Visual Studio Code lag when saving a file
Kim, Chuck 0 Reputation points
2026-03-13T19:24:31.7766667+00:00
I've been using VS Code to modify HTML files for work for a number of years. Since the update before the current one installed, I've noticed that it takes a really long time (> 20 seconds) for Code to respond after saving a file (using Ctrl+s or Ctrl+Shift+S).
Process:
  1. Make edits in an open HTML file.
  2. Use the Ctrl+s keyboard shortcut to save the file.
  3. Wait for a really … long … time (typically > 20 sec.) … Case 1 (previous release)
  4. Try to do anything else … get a popup box asking if you want to **Wait** (or close or refresh, IIRC).
  5. After clicking **Wait**, VS Code eventually responds as expected (sometimes taking 1–3 seconds).
… Case 2 (since the latest release) 4. Try to do anything else … lag (typically 1–3 seconds). 5. After the wait, VS Code eventually responds as expected.
Current version info:
Version: 1.111.0 (system setup)
Commit: ce099c1ed25d9eb3076c11e4a280f3eb52b4fbeb
Date: 2026-03-06T23:06:10Z
Electron: 39.6.0
ElectronBuildId: 13330601
Chromium: 142.0.7444.265
Node.js: 22.22.0
V8: 14.2.231.22-electron.0
OS: Windows_NT x64 10.0.26200
Developer technologies | Visual Studio | Other
A family of Microsoft suites of integrated development tools for building applications for Windows, the web, mobile devices and many other platforms. Miscellaneous topics that do not fit into specific categories.
    2026-03-13T19:24:49.48+00:00
    The context only covers Visual Studio (full IDE) performance, not Visual Studio Code, so only general, supported guidance can be given.
    The behavior described matches an extension or background process blocking the UI on save rather than a core VS Code bug confirmed in the provided context. To narrow it down and mitigate:
    1. Check if it’s solution/project related
      • Open a single small HTML file outside any workspace (File → Open File) and save it repeatedly.
      • If saves are fast there, the slowdown is likely tied to the workspace (tools watching the folder, build tasks, etc.).
    2. Disable extensions to isolate the cause
      • Temporarily disable all extensions (run VS Code with extensions disabled).
      • If saving is fast with extensions disabled, re-enable them in batches until the lag returns to identify the problematic extension (for example, formatters, linters, live servers, or HTML-related plugins).
    3. Check for heavy save-time actions
      • Look for configured format-on-save, lint-on-save, or build-on-save tasks in settings or workspace configuration.
      • Temporarily turn off these features and test again. If performance improves, re-enable only what is essential or adjust their scope.
    4. Monitor CPU usage during save
      • While reproducing the issue, open Task Manager and watch VS Code and any related processes (e.g., Node, language servers). High CPU usage during the 20+ seconds indicates an expensive operation on save.
    5. Capture a performance trace and report it
      • The Visual Studio guidance for slowness and high CPU issues also applies conceptually: a performance trace captured while the slow operation is happening makes the issue actionable.
      • Start VS Code, prepare a minimal repro (same file and steps), then use its performance tools (Developer: Open Process Explorer / Developer tools) to record while saving.
      • Include that trace in an issue report so the product team can investigate, similar to how Visual Studio issues are handled in the “Increase the chances of a performance issue being fixed” guidance.
    6. Avoid heavy auto-restore/auto-open scenarios
      • In Visual Studio, reopening many documents and designers on solution load can significantly slow performance. The analogous pattern in VS Code is having many large or complex files and folders open, with multiple watchers and language services active.
      • Close unneeded folders and files, and avoid very large workspaces when editing a single HTML file.
    If, after disabling all extensions and simplifying the workspace, saving is still consistently slow, capture a performance trace during the save and submit it to the VS Code issue tracker so the team can analyze the regression in the specific build listed.
