Outlook will not open, it keeps asking me to create account, and I can't unistall it.
Karl Poeltl 0 Reputation points
2026-03-13T16:41:03.81+00:00
I have been using outlook classic for many years. Today it wasn't downloading one on my Gmail accounts so I selected "Try new Outlook" in the upper right corner of the screen because sometimes when I have errors on Outlook Classic, useing the new version for a short while seems to reset the classic version and Classic will start working again. But today the new Outlook is asking me to sign in,.. and when I enter my account and password the screen shows something like "setting up" and then it goes right back to asking me to sign in. Also,.. the new Outlook seems to have written itself over the classic Outlook so even when I click on the old outlook pin to open it diectly it still goes to the new outlook and asks me to sign in etc.. in an infinate loop. I have read that I should try to remove Outlook and reinstall but I can't do that either,.. the remove program app for outlook simply says it could not be uninstalled.
Anyone have any ideas??
    2026-03-13T16:41:18.58+00:00
    Follow these steps in order.
    1. Force-close Outlook
    • Right-click Start and select Task Manager.
    • Select Microsoft Outlook, then choose End task.
    • Confirm Outlook is fully closed, then close Task Manager.
    1. Clear the new Outlook sign-in/cache data This often fixes sign-in loops and launch problems.
    • Close all Microsoft apps (Outlook, Teams, Word, etc.).
    • Press Windows + R, type appdata, and press Enter.
    • Go to Local > Microsoft.
    • Delete these folders if present:
      • Olk
      • OneAuth
    • Restart the PC.
    • Try launching Outlook again (from the Start menu). If prompted, sign in and let it complete setup.
    1. If Outlook still will not open, repair or reinstall Office instead of just Outlook If the standalone Outlook uninstall fails, repairing or reinstalling the full Office suite typically resolves it.
    • Use the Office repair/uninstall from Apps & Features (or Programs and Features) to remove Office 365/Office desktop apps.
    • After uninstall completes, reinstall Office from the Microsoft 365 subscription portal or installation source.
    • Open Outlook again and sign in/add accounts.
    1. If classic Outlook opens but behaves incorrectly, create a new Outlook profile A corrupted profile can prevent Outlook from starting or working correctly.
    • Close Outlook.
    • Open Control Panel.
    • Select Mail > Show Profiles.
    • Choose Add, give the profile a name, and select OK.
    • Enter the primary email address and password and complete the setup wizard.
    • Back in Show Profiles, select Prompt for a profile to be used (or set the new profile as default).
    • Start Outlook and choose the new profile.
    If Outlook works with the new profile, the old profile is corrupted and can be deleted later (after backing up any needed data files).
