A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
When VLOOKUP returns #N/A even though the value appears to exist, the cause is usually one of these issues:
- The lookup value is not an exact match
- If
range_lookupis FALSE (exact match), #N/A means the exact value is not found in the first column of the table_array. - Common reasons:
- Extra spaces before/after the value in either the lookup cell or the table.
- One is stored as text and the other as a number.
- Hidden characters or different formatting.
- If
- The lookup value is outside the range when using approximate match
- If
range_lookupis TRUE or omitted, and the lookup value is smaller than the smallest value in the first column of the table_array, VLOOKUP returns #N/A. - In this mode, the first column must be sorted alphabetically or numerically; otherwise results can be unexpected.
- If
To troubleshoot:
- Check the
range_lookupargument- Use
FALSEfor exact match:=VLOOKUP(lookup_value, table_array, col_index_num, FALSE).
- Use
- Clean the data
- Remove leading/trailing spaces and ensure both lookup_value and first column of table_array are the same type (both text or both numbers).
- Confirm the lookup column
- Ensure the value really exists in the first column of the table_array range used in VLOOKUP.
If the #N/A is expected (for example, when the value truly does not exist), wrap the formula in an error handler to control the output, such as:
=IFERROR(VLOOKUP(...), "Not found")to handle any error, or -
=IFNA(VLOOKUP(...), "Not found")to handle only #N/A specifically.
The IFNA function returns the value specified if the formula returns #N/A; otherwise it returns the formula result.
