Hi Dwight Johnson,
Thank you for sharing the details. When Bluetooth stops working after a Windows Insider Preview update, it’s usually related to how the system refreshes device drivers during the update.
In addition to Q&A Assist's answer, please follow the steps below to ensure the Bluetooth driver and services are correctly restored:
1, Clean reinstall the Bluetooth driver
- Open Device Manager
- Expand Bluetooth
- Right‑click the Bluetooth adapter and select Uninstall device
- Check Delete the driver software for this device
- Shut down the PC completely, then power it back on
2, Force hardware detection (if Bluetooth doesn’t reappear)
- Select Action > Scan for hardware changes
3, Roll back the driver (if available)
- In Device Manager, right‑click the Bluetooth adapter
- Select Properties > Driver
- Choose Roll Back Driver if the option is available
4, Install the device manufacturer’s Bluetooth driver
- Download the latest Bluetooth driver directly from your PC or motherboard manufacturer’s support site
- Install the driver and restart the device
5, Verify Bluetooth services
- Press Win + R, type
services.msc - Ensure Bluetooth Support Service is set to Running and Startup type: Automatic
6, Run the built‑in Bluetooth troubleshooter
- Go to Settings > System > Troubleshoot > Other troubleshooters
- Run the Bluetooth troubleshooter
I appreciate you taking the time to work through these steps. Let me know if you need further assistance, feel free to ask me by clicking "Add Comment" or "Add Answer" if you cannot add comment so your response will be visible. Thanks for your effort.
