Background graphics are disappearing when I copy and paste divider slides....
GabrielleG 20 Reputation points
2026-03-12T20:22:07.7533333+00:00
In the latest version of powerpoint - (working on a hard drive - not in the cloud) - We have created in the master template - a title slide and a divider slide. Both slides have a background image. This image has been placed >format background > image, AND we have also tried placing a full slide sized jpeg as a placed image on the master slide.
After saving and closing the master templates - we started to build our presentation. We added a new slide - selecting the divider slide. We placed content slides.
When we went back to the divider slide > we CUT and PASTED it later in the document - and the background image disappeared. The little clipboard icon popped up and asked if it should keep the original formatting - When you click YES the background graphics re-appear. If you don't click it - PPT ADDS a NEW master template - with a similar layout and NO background graphics. (so weird!)
This has NEVER happened before. Usually when you cut and paste slides within the SAME presentation they hold their formatting. This is not happening.
Any thoughts? (PS this is also happening on my PC too)
Microsoft 365 and Office | PowerPoint | Other | Other
Kal-D 7,375 Reputation points Microsoft External Staff Moderator
2026-03-19T21:29:57.39+00:00
Hi GabrielleG,
What you’re describing usually indicates that PowerPoint is reassigning the slide to a different layout during cut/paste, rather than keeping it attached to the original Slide Master layout. When destination formatting is applied, PowerPoint can create a new, similar layout that doesn’t include the background image, which explains why the background returns only when Keep original formatting is selected.
A few things you can try:
  1. Move the slide without cut/paste
Try dragging the slide thumbnail to the new location, or use Duplicate Slide (Ctrl+D) and then delete the original. These methods often preserve the original layout connection more reliably.
  1. Reapply the intended layout
After pasting, go to Home > Layout, reselect the original Divider layout, then choose Home > Reset.
Please note that Reset restores the layout’s default formatting and placeholder positions, so any manual adjustments to placeholders may be reverted, although slide content itself is not removed.
  1. Check for duplicate masters
In View > Slide Master, check whether a second master or layout was created during paste. If so, the slide may have been reassigned to that duplicate instead of the original layout containing the background.
  1. Test in a clean presentation
Rebuilding just the divider layout in a new file can help confirm whether this is a template/layout reference issue rather than a problem with the background image itself.
  1. Save a corrected template
If the behavior is resolved in a clean file, saving it as a .potx can help preserve the corrected master/layout structure going forward.
Since this occurs on more than one PC, it points more toward the presentation or template structure than the device or image.
Please let me know if this proves useful to you, or if you would like further assistance.
I'm looking forward to your reply.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment”.
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
1 additional answer
    2026-03-12T20:22:22.2866667+00:00
    PowerPoint is treating the pasted divider slide as if it might be coming from another presentation and is switching its layout to a new, background‑less layout when the paste options are not confirmed. The behavior is tied to how the slide master and layouts are applied, not to the image itself.
    To keep the background graphics from disappearing and avoid extra masters being created:
    1. Use the existing layout from the master instead of the auto‑created one:
      • After pasting the divider slide, select it in Normal view.
      • Go to Home > Layout and explicitly choose the divider layout that was defined in Slide Master view. This reapplies the correct layout and background to that slide.
      • If other slides have already picked up the new, background‑less layout, select them and reapply the correct layout the same way.
    2. Make sure the divider layout is correctly defined on the slide master:
      • Go to View > Slide Master.
      • Select the divider layout under the master.
      • Apply the background image using Background Styles > Format Background > Picture or texture fill, then Close Master.
      • This ensures the background is part of the layout, so reapplying the layout restores it on any affected slide.
    3. Clean up unwanted extra masters/layouts:
      • In View > Slide Master, delete any extra slide masters or layouts that PowerPoint created without backgrounds (select them and choose Delete on the Slide Master tab).
      • This reduces the chance that pasted slides will attach to the wrong master.
    If the issue persists across machines and files, it can indicate a corruption or version‑specific problem. In that case, recreating the template from a fresh blank presentation and re‑defining the slide master and divider layout (then saving as a template) often resolves master/layout glitches.
