I need help to fix error code 7Q6CA and another issue
2026-03-10T19:51:40.7666667+00:00
Xbox Gamertag: TealCastle68402
Minecraft User: chillhomie_Aabid
on February 21 2026 I was playing Minecraft the whole day practicing my pvp skills and then on the 22nd Minecraft was open and I was going to play donut smp on my mac m2 air 2022 and it said restart the launcher and Minecraft and reopen it again and then I did but then it had logged me out but it normally doesn't do that so I tried to login but whenever I tried it said "please make sure this account exists and I kept trying and trying I tried to recover didn't work after I looked up videos about how to fix this and nothing then I went on my windows pc and opened edge and at the top right corner where it usually shows your profile picture right next to it said verify it's you I tried and it didn't work it just showed error code 7Q6CA and then it showed
"Correlation Id: 77e0cde7-87d2-43b2-b74f-f44c67466b46
Timestamp: 2026-03-10T19:10:35.000Z
DPTI: e24c441ec17fe05af9d2c7b5ed6ca0374ad6b6f2457e4c0381a1d3ff9ccc61f3
Message: An unexpected error occurred.
Tag: 7q6ca
Code: 2147483661"
sorry this one is newer than all because i had to copy it
sooner or later i stumbled across a video to tap create a new account and then the issue will be solved i tried it but i was very hesitant at first and looked for alternatives and the comments say that it worked so i did now whenever i try to sign in it shows the new account as it won't let me choose which i account i can choose but when i go to edge it still shows verify its you and my old profile picture and im trying to get my old account back and i have proof i have had this account way before 2024 now i need help with this
Microsoft Edge | Profile, sync, and sign in | Windows 10
    2026-03-10T19:52:08.2833333+00:00
    Error code 7Q6CA and the “Verify it’s you” loop indicate a Microsoft account sign-in / security verification problem, not a Minecraft or Edge bug. The account is effectively blocked behind security checks, so the only supported way to regain access is through the official Microsoft account recovery and verification flows.
    Follow these steps in order:
    1. Use the official sign-in helper
    • Go to the Microsoft sign-in helper tool: Sign-in helper.
    • Enter the email/phone/Skype ID of the original Microsoft account that was used for Minecraft and Xbox.
    • Let the tool run and follow the guidance it gives (it can detect common sign-in and security issues and route to the right flow).
    1. Try standard account recovery If normal sign-in fails, use the official recovery form for the old account:
    2. Go to Recover your account: Recover your account.
    3. Enter the email address, phone number, or Skype name of the old account.
    4. Choose where to receive a security code (email/phone) and complete the verification.
    5. Set a new password when prompted.
    Tips from the official guidance:
    • Make sure the email domain is correct (for example, .com vs .co.uk).
    • Check for spelling differences in the name part (for example, rachel vs rachael).
    • If the email isn’t recognized but the account had another alias or phone number, try that instead.
    If the username and password are correct but still do not work, follow the same “Recover your account” flow above. If the system says “We couldn’t find an account with that username,” use any other alias/phone that was ever attached to that Microsoft account.
    1. If verification codes are the problem If the issue is that verification codes are not arriving or a method is blocked:
    • Try a different browser or InPrivate/Incognito mode.
    • Clear browser cache and cookies, then try again.
    • Try a different network (for example, mobile hotspot instead of home Wi‑Fi).
    • If there are multiple verification methods on the account, choose a different one.
    If codes still do not arrive, the guidance is:
    • Choose another verification method if possible, or wait until access to the listed phone/email is available.
    • Support agents cannot send verification codes or change security info for the account.
    See: Troubleshoot Microsoft verification code issues.
    1. If recovery fails or the account appears blocked If the recovery form or sign-in helper still does not let access the old account:
    2. Fill out the detailed Microsoft account recovery form (ACSR) at https://account.live.com/acsr (from the context) for the original account.
    3. Provide as many accurate details as possible (previous passwords, approximate creation date, services used like Xbox/Minecraft, etc.).
    4. Submit from a device and location normally used with that account.
    If the form is rejected repeatedly, community and Q&A guidance is clear: only the automated recovery process can restore access. Forum moderators and normal support channels cannot bypass or override these security checks.
    1. Contact Microsoft Support (if still locked out) If the automated tools do not resolve it, sign in with any working Microsoft account (even the new one) and contact support:
    • Go to Contact Microsoft Support.
    • Enter a description like “Microsoft account sign-in blocked / error 7Q6CA / cannot verify identity.”
    • Select Get Help, then scroll down and choose Contact Support.
    • Pick the product area related to account security (for example, “Manage Account Security”) and use chat/callback if offered.
    Support cannot reset passwords or bypass security, but can confirm what options remain and ensure the correct recovery path is being used.
    1. About Minecraft and Xbox access Once the original Microsoft account is recovered and can sign in again:
    • Sign into that account in the Minecraft Launcher on Mac and Windows.
    • Sign into that same account on Xbox / Xbox app to restore the gamertag and purchases.
    If the original Microsoft account cannot be recovered at all, Minecraft-specific purchases may require contacting Minecraft Support separately (as suggested in the Q&A context) to see if any alternative options exist.
