How to delete my user review on Microsoft edge extension.
Sameer Zafar 0 Reputation points
2026-03-06T17:37:18.2566667+00:00
I submitted a review on a Microsoft Edge extension and now I don’t have a delete option so how do I remove this review from my Microsoft account?
Microsoft Edge | Browser extensions | Windows 11
    2026-03-06T17:37:28.2733333+00:00
    Deleting a review for a Microsoft Edge extension is done through the same mechanism as other public feedback and reviews tied to a Microsoft account.
    1. Sign in with the same Microsoft account that was used to post the review.
    2. Go to the feedback/review area associated with that account (for example, the “My feedback” or “My reviews” section, depending on the portal being used).
    3. Locate the specific feedback item or review for the Edge extension.
    4. Open it and choose the option to delete/remove it. When deleting, all associated comments, votes, flags, and follows for that feedback item are removed, and the deletion is irreversible.
    If the review was submitted through a public feedback portal rather than directly in the Microsoft Edge Add-ons listing, use the “My Feedback” section of that portal to delete it. If the review cannot be found or no delete option appears, submit new feedback to Microsoft Edge using Settings and more > Help and feedback > Send feedback and request removal of the specific review, including as much identifying detail as possible (extension name, approximate date, and content of the review).
  2. Thomas4-N 22,010 Reputation points Microsoft External Staff Moderator
    2026-03-12T08:06:35.2633333+00:00
    Hello Sameer Zafar,
    The Microsoft Edge Add-ons store doesn't currently have a self-service option to edit or delete a submitted review. To request removal, use the "Report as spam or abuse" link that appears directly under the review on the extension's page — which sends a removal request to the Edge Add-ons team.
