Error message: interaction_required: AADSTS5000225: This tenant has been blocked due to inactivity. To learn more about tenant lifecycle policies, see https://aka.ms/TenantLifecycle Trace ID: e033d54b-cde4-4880-815c-915395917300 Correlation ID: 019cc31e-8
Clive Reece 0 Reputation points
2026-03-06T12:33:14.7333333+00:00
Not able to log into portal.azure.com, the following error is received:
Error message: interaction_required: AADSTS5000225: This tenant has been blocked due to inactivity. To learn more about tenant lifecycle policies, see https://aka.ms/TenantLifecycle Trace ID: e033d54b-cde4-4880-815c-915395917300 Correlation ID: 019cc31e-8b98-7954-bb19-ab4df45fe8b6 Timestamp: 2026-03-06 12:28:06Z
Microsoft Security | Microsoft Entra | Other
    2026-03-06T12:33:27.93+00:00
    The error interaction_required: AADSTS5000225: This tenant has been blocked due to inactivity indicates that the Microsoft Entra/Azure AD tenant is in an inaccessible state due to inactivity and is being processed for deletion.
    Key points from the tenant lifecycle behavior:
    • When a tenant is marked inactive, sign-ins are blocked and this exact error is expected.
    • Administrators have a limited window of 20 days from when the tenant becomes inaccessible to request reactivation.
    • If the tenant remains inaccessible for more than 20 days, it is deleted and cannot be recovered.
    Next steps depend on the tenant’s state and role:
    1. If within 20 days of being blocked (tenant admin):
      • The tenant’s global administrator must contact Microsoft Support and request reactivation.
      • Use the global support phone numbers listed in the documentation and open only one assistance request; do not submit multiple tickets while the first is in progress.
    2. If more than 20 days have passed since it was blocked:
      • The tenant is deleted and is not recoverable.
      • Review Microsoft’s data protection policies for details on data handling and retention.
    3. If accessing as an application owner/developer:
      • Minimize authentication requests to the blocked tenant until it is reactivated.
      • Do not open multiple assistance requests; wait for the decision on any existing case.
    If access to Azure Portal is needed for other work and this tenant cannot be recovered, create or use another active tenant and sign in with that tenant’s domain or ID.
