A high-performance, durable block storage designed to be used with Azure Virtual Machines and Azure VMware Solution.
To safely identify and clean up old Azure disks, use a combination of “attachment state” and metadata.
- Identify whether disks are attached (in use)
Managed disks (current default):
- In the Azure portal:
- Go to Disks.
- Open each disk and check Disk state.
- If it shows Unattached, the disk is not currently used by any VM and is a candidate for cleanup.
- At scale, use the Azure CLI script described in the managed-disk article:
- It checks the ManagedBy property of each disk.
- If ManagedBy is
null, the disk is unattached. - First run with
deleteUnattachedDisks = 0to only list disks; after review, re-run withdeleteUnattachedDisks = 1to delete them.
Unmanaged disks (older model, .vhd page blobs):
- These are VHD files stored as page blobs in storage accounts.
- Use the PowerShell script from the unmanaged-disk article:
- It scans all storage accounts and checks the LeaseStatus of each page blob.
LeaseStatus = Locked→ attached to a VM. -
LeaseStatus = Unlocked→ unattached. - The script has
deleteUnattachedVHDs = $falseby default so it only reports; set to$trueto delete after review.
- Check whether a VHD is attached to a specific VM
When trying to delete a storage account/container/blob and you see lease errors, Azure is protecting attached VHDs:
- In the portal:
- Go to the storage account → Containers → locate the VHD blob.
- If Lease State is Leased, open Edit metadata.
- Look at:
MicrosoftAzureCompute_VMName→ name of the VM using the VHD. -
MicrosoftAzureCompute_DiskType→OSDiskorDataDisk.
- If these metadata fields are missing but the blob is leased, it is explicitly leased and not attached to a VM; break the lease before deletion.
- Understand “where they originated from”
For unmanaged VHDs:
- The metadata fields above (
MicrosoftAzureCompute_VMName,MicrosoftAzureCompute_DiskType) tell which VM originally used the disk and whether it was OS or data.
For managed disks:
- The ManagedBy property (when not null) contains the resource ID of the VM currently using the disk.
- For disks that are now unattached, use:
LastOwnershipUpdateTime(viaaz disk show) to see when the disk was last attached/detached. - Naming conventions, resource group names, and tags (if used historically) to infer original purpose.
- Safely clean up
Recommended process:
- Enumerate all disks and classify:
- Managed vs unmanaged.
- Attached vs unattached.
- For each unattached disk:
- Confirm no current VM references it (via
ManagedByor blob metadata). - Optionally take a backup (for example, Azure Disk Backup or snapshot) before deletion.
- Delete only after:
- Verifying it is unattached.
- Verifying it is not needed for any restore or legacy scenario.
Remember that disk deletions are permanent; data cannot be recovered once a disk or VHD is deleted unless a separate backup exists.
- Find and delete unattached Azure managed and unmanaged disks - Azure portal
- Find and delete unattached Azure managed and unmanaged disks by using Azure PowerShell
- Find and delete unattached Azure managed and unmanaged disks by using the Azure CLI
- Troubleshoot storage resource deletion errors
- Restore Azure Disks using Azure Data Protection REST API
