Fix if you're connected to hotspot ore domain network contact the network administrator
Andy Appiah 0 Reputation points
2026-03-03T16:08:21.5933333+00:00
My pc says if you're connected to hotspot ore domain network contact the network administrator
Windows for home | Other | Internet and connectivity
    2026-03-03T16:08:37.2966667+00:00
    The message indicates a general network connectivity problem on Windows, not something specific to Teams. Use these steps on the PC to troubleshoot the network connection first, then try Teams again:
    1. Check Wi‑Fi or Ethernet status
      • Select the Network, Sound, or Battery icon on the right side of the taskbar.
      • Make sure Wi‑Fi is turned on (if using wireless).
      • Confirm the network shows as Connected. If not, select the correct Wi‑Fi network and connect.
      • If using Ethernet, ensure the cable is firmly plugged into both PC and router.
    2. Run the Network troubleshooter
      • Select Start > Settings > Network & Internet.
      • Select Status (Windows 10) or the equivalent network page.
      • Scroll down and select Network troubleshooter.
      • Follow the on‑screen steps and apply any fixes it suggests.
    3. Try another device on the same network
      • Connect a phone or another PC to the same Wi‑Fi or hotspot.
      • If other devices have internet, the issue is likely with this PC.
    4. Reset network components via Command Prompt
      • Select Search on the taskbar, type command prompt.
      • Right‑click Command Prompt > Run as administrator > Yes.
      • Run these commands one by one, pressing Enter after each:
        • netsh winsock reset
        • netsh int ip reset
        • ipconfig /release
        • ipconfig /renew
        • ipconfig /flushdns
      • Restart the PC and test the connection and Teams again.
    5. If still no internet: use Network reset (last resort)
      • Select Start > Settings > Network & internet.
      • On Windows 11: Advanced network settings > Network reset.
      • On Windows 10: Status > Network reset.
      • Select Reset now > Yes, let the PC restart, then reconnect to Wi‑Fi or Ethernet and sign back into Teams.
      • Note: This removes and reinstalls network adapters and resets settings; VPN and virtual switch software may need to be reinstalled.
    If the PC is actually joined to a school or work domain or using a managed hotspot, the network administrator may have restricted access; in that case, contact the school or organization IT support as the message suggests.
