Issue Loading Project in Microsoft Azure
Amanj Anwer Qoubadi 0 Reputation points
2026-03-02T10:06:45.36+00:00
Dear Microsoft Azure Support Team,
I am currently experiencing an issue while trying to access my project in Microsoft Azure under the software section. When I attempt to load the project, nothing appears on the screen.
I have tried several troubleshooting steps, including refreshing the page, logging out and back in, clearing my browser cache, and using a different browser, but the issue still persists. Unfortunately, I have not been able to resolve the problem.
Could you please assist me in identifying the cause of this issue and guide me on how to fix it? I would appreciate your support as soon as possible.
Thank you in advance for your help.
Kind regards, Amanj Anwer Qoubadi
Microsoft Copilot | Other
    2026-03-02T10:07:03.2733333+00:00
    Follow these steps to troubleshoot the issue where the Azure project page loads but shows nothing:
    1. Complete sign-out and browser cleanup
      • Go to https://aka.ms/VsSignout to sign out of all Microsoft identities used with Azure DevOps/Azure.
      • After sign-out, clear browser data (Ctrl+Shift+Delete):
        • Cookies and site data
        • Cached images and files
        • Autofill form data
      • Close all browser windows completely.
    2. Test with a private/incognito session
      • Open a new InPrivate/Incognito window in the browser.
      • Navigate to the Azure DevOps or Azure portal URL for the project.
      • Sign in with the account that should have access to the project.
    3. Verify correct account and identity
      • If there are multiple Microsoft accounts (work/school and personal), ensure sign-in with the account that actually has access to the project.
      • If a 401 or access denied–type behavior appears, repeat sign-out using https://aka.ms/vssignout and choose a different identity when signing back in.
    4. Check access and permissions to the project
      • Confirm that the account is a member of the correct Azure DevOps organization/project and has at least Project access.
      • If the project still appears blank, an administrator should verify:
        • Access level supports the service/feature being opened.
        • The user is not in a restricted security group (for example, project-scoped or limited-scope group) that blocks access.
        • No explicit deny permissions are set for that user or group.
        • The relevant service (Boards/Repos/Pipelines, etc.) is not disabled at project or collection level.
      • After any permission changes, refresh the browser so the new permissions are recognized.
    5. Network and environment checks
      • If using a corporate network, test from a different network (for example, home or mobile hotspot) to rule out proxy/firewall issues.
      • Ensure the corporate proxy or firewall allows access to Azure DevOps endpoints (for example, *.visualstudio.com, *.azure.com).
    6. If the project is opened via Visual Studio
      • In Visual Studio, remove existing Azure DevOps connections from Team Explorer.
      • Clear cached credentials from Windows Credential Manager.
      • Restart Visual Studio and add the Azure DevOps connection again using the correct account.
    7. Collect diagnostics and contact support if still failing
      • Capture a browser trace of the failed load following the guidance in the connection troubleshooting article.
      • Create a support request and include:
        • Exact organization/project URL.
        • Date/time and time zone of the failed attempts.
        • Steps already tried (browsers, private mode, sign-out, cache clear, account used).
        • Browser trace files and screenshots of the blank/failed page.
    These steps address the most common causes: cached/incorrect identities, browser issues, missing permissions, and network restrictions.
