How can i get my power point slides to insert a chart, if excel has already been installed?
Gonzalez, Luz 0 Reputation points
2026-03-02T00:25:26.3666667+00:00
I am editing power point slides but for some reason it is not allowing me to insert any kind of chart. Each time I try to insert a chart it tells me I need to instal excel, when excel is already installed.
Microsoft 365 and Office
A comprehensive suite of productivity tools and cloud services that enhance collaboration, communication, and efficiency. Combining classic Office apps with advanced Microsoft 365 features, it supports both personal and business needs
    2026-03-02T00:25:35.8933333+00:00
    PowerPoint requires a working Excel installation to create or edit charts. If PowerPoint cannot detect Excel correctly, chart insertion fails even if Excel is installed. Use one of these workarounds:
    1. Create the chart directly in PowerPoint (if available in the version):
      1. In PowerPoint, go to Insert > Chart.
      2. Choose the chart type (bar, pie, line, etc.) and double-click it.
      3. In the worksheet that appears, replace the placeholder data with the required data.
      4. Close the worksheet when finished.
    2. Create the chart in Excel and copy it into PowerPoint:
      1. Open Excel and create the chart using the data.
      2. Click the chart and press Ctrl+C (or right‑click > Copy).
      3. Switch to PowerPoint, click where the chart should appear, and press Ctrl+V.
      4. Use Paste Options to choose whether to keep it linked to Excel, embed it, or paste as a picture. For example, select Use Destination Theme & Link Data to keep it linked so updates in Excel reflect in PowerPoint.
    If PowerPoint still insists Excel is not installed when using Insert > Chart, use method 2 as a reliable workaround while resolving the underlying Office installation issue (for example, by repairing or reinstalling Office so PowerPoint can detect Excel again).
