Lab Issue-Node.js Version incompatibility - Instance ID: 59508821
2026-02-26T22:43:45.7266667+00:00
I am currently working on the assessment lab 'Extend Microsoft 365 Copilot with declarative agents by using Visual Studio Code'.
My lab instance ID is: 59508821
I am unable to provision Agent 0 due to a Node.js version incompatibility. The TypeSpec compiler requires a minimum of Node.js v20, however the lab environment has Node.js v18.16.0 installed, and I do not have admin credentials to update it.
Error message: 'yargs parser supports a minimum Node.js version of 20'
Could you please update Node.js to v20 or higher on my lab instance, or provide an alternative solution?
Thank you for your help.
Microsoft Copilot | Other
    2026-02-26T22:43:57.2066667+00:00
    The TypeSpec tooling and its yargs dependency requiring Node.js 20+ is a hard runtime requirement. The lab environment currently providing Node.js 18.16.0 does not meet that requirement, and the context does not describe any supported way to override or bypass the Node.js version inside a managed lab environment without admin rights.
    The only supported guidance in the context for Node.js version mismatches is:
    • Azure SDKs and related tooling require supported LTS versions of Node.js and must be updated when the runtime is older than the minimum supported version.
    • All environments (local dev, CI/CD, and host) should align on the same Node.js LTS version to avoid compatibility issues such as syntax errors, dependency conflicts, and build failures.
    In a managed lab where Node.js is preinstalled and cannot be upgraded by the learner, this becomes an environment issue rather than something that can be fixed from within the lab session. The appropriate action is to escalate to the lab or course support team so the lab image can be updated to Node.js 20 or higher.
    Because the context does not provide an officially supported workaround (such as an alternate local environment path or a documented way to install a newer Node.js inside the lab without admin rights), the only supported resolution from the provided information is to request that the lab environment be updated to a supported Node.js LTS version (20 or later) so the TypeSpec compiler and its dependencies can run successfully.
