An Azure service that provides access to OpenAI’s GPT-3 models with enterprise capabilities.
If you are successfully signed into the Azure portal with your college email but do not see an active Azure for Students subscription, there are a few steps you can take to troubleshoot the issue:
- Verify Eligibility: Ensure that you meet the eligibility requirements for Azure for Students. You must be a full-time student at an accredited institution and verify your academic status through your college email.
- Check for Existing Subscription: Sometimes, if you have previously signed up for Azure for Students, you may not be able to create a new subscription. Check if you already have an existing subscription that may not be visible.
- Contact Support: If you are still unable to activate your subscription, it is recommended to contact Azure support for assistance. They can help you with the verification process and any issues related to your account.
- Try Again Later: Occasionally, there may be temporary issues with the Azure portal. If you have verified your eligibility and are still facing issues, try again after some time.
By following these steps, you should be able to troubleshoot the activation of your Azure for Students subscription.
