third party anti virus products
Guy Russell 20 Reputation points
2026-02-24T15:20:34.0266667+00:00
I am operating a desktop device using Windows 11 for a home device. Is a third party anti virus (e.g. McAfee or Norton) a recommended step up in anti virus protection?
Marcin Policht 109.3K Reputation points MVP Volunteer Moderator
2026-02-24T15:30:57.0166667+00:00
For a typical home Windows 11 desktop, a third-party antivirus such as McAfee or Norton is generally not a meaningful “step up” in protection compared to the built-in Microsoft Defender Antivirus. Microsoft Defender in Windows 11 provides real-time protection, cloud-based threat detection, ransomware protection (including Controlled Folder Access), SmartScreen filtering, firewall integration, and automatic updates through Windows Update. In independent testing labs (such as AV-TEST and AV-Comparatives), Defender consistently scores at or near the top for detection and protection, often matching major third-party products.
For most home users, overall security depends more on system configuration and behavior than on switching antivirus engines. Keeping Windows fully updated, enabling automatic updates, using a standard (non-admin) account for daily work, enabling SmartScreen, maintaining secure browser practices, and avoiding unknown downloads typically provide more measurable risk reduction than installing an additional antivirus suite.
Third-party antivirus products may provide extra features such as bundled VPN services, identity monitoring, password managers, or more granular firewall controls. However, these are feature additions rather than core malware detection improvements. They can also introduce system overhead, additional notifications, subscription costs, and occasionally compatibility issues. Windows Defender is tightly integrated with the operating system and generally has minimal performance impact.
If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
hth
Marcin
0 additional answers
