Document Intelligence Studio: Chrome/Edge blocked by Private Network Access (PNA) – Cognitive Services endpoint missing Access-Control-Allow-Private-Network header
MS 0 Reputation points
2026-02-24T09:08:33.37+00:00
Setup
We are using Azure AI Document Intelligence Studio (contentunderstanding.ai.azure.com) to manage labeling projects and custom models. Our Document Intelligence resource is configured with a private endpoint only — public network access is disabled to comply with our organization's security policies.
  • Resource endpoint: <our-resource>.cognitiveservices.azure.com
  • Network: Private endpoint only, resolves to a private IP (e.g. 10.x.x.x)
  • Public access: Disabled
  • Region: West Europe
Problem
Since Chrome 130+ and now also Edge 143+, browsers enforce Private Network Access (PNA) checks (see Chrome PNA specification).
When Document Intelligence Studio (contentunderstanding.ai.azure.com, a public website) makes API calls to our Cognitive Services endpoint, the browser detects that the target resolves to a private IP address. This triggers a PNA preflight request (OPTIONS), and the browser expects the following header in the response:
Access-Control-Allow-Private-Network: true
Azure Cognitive Services does not return this header. As a result, Chrome and Edge block the request entirely before the actual API call is even made.
Example of a blocked request
Request URL: https://<our-resource>.cognitiveservices.azure.com/documentintelligence/labelingProjects?api-version=2024-11-30
DevTools error:
Access to fetch at 'https://<our-resource>.cognitiveservices.azure.com/...' from origin
'https://contentunderstanding.ai.azure.com' has been blocked by CORS policy:
No 'Access-Control-Allow-Private-Network' header was present in the preflight response
for this private network request targeting the private address space.
Browser behavior
Browser PNA enforced Studio works
Chrome 130+ Yes No
Chrome 130+ Yes No
Edge 143+ Yes No
Firefox Not yet Yes (for now)
Current workarounds (all unsatisfactory)
  1. Disable Chrome flag chrome://flags/#local-network-access-check — not viable for production or managed enterprise devices (may be locked via Group Policy).
  2. Use Firefox — not a sustainable solution; Firefox will implement PNA eventually.
  3. Enable public access on the Cognitive Services resource — this defeats the entire purpose of private endpoints and violates our security requirements.
  4. Place Azure API Management or Azure Front Door in front of the endpoint to inject the header — this adds significant cost and architectural complexity just to work around a missing response header.
Request
Please add the Access-Control-Allow-Private-Network: true header to the OPTIONS preflight response on *.cognitiveservices.azure.com when the resource is accessed via private endpoints.
This is a server-side change on the Azure platform. It would immediately resolve the issue for all customers using Document Intelligence Studio (and potentially other Azure portal-based tools) with private endpoints — without requiring any workarounds or additional Azure services.
Environment
  • Chrome 142+ / Edge 143+
  • Azure AI Document Intelligence Studio (contentunderstanding.ai.azure.com)
  • Azure Cognitive Services with private endpoint, public access disabled
Azure Document Intelligence in Foundry Tools
    2026-02-24T09:09:12.93+00:00
    The issue you're encountering with the Azure AI Document Intelligence Studio and the enforcement of Private Network Access (PNA) checks in recent versions of Chrome and Edge is indeed a challenge for users who have configured their Cognitive Services with private endpoints and disabled public access. The requirement for the Access-Control-Allow-Private-Network header in the preflight response is a new security measure implemented by browsers to protect users from potential security risks when accessing private network resources from public origins.
    Currently, Azure Cognitive Services does not return this header, which leads to the blocking of requests made from the Document Intelligence Studio to your private endpoint. Unfortunately, there are no direct solutions available within the Azure platform to modify server-side responses for this specific issue at this time.
    As you noted, the workarounds you mentioned are not ideal, especially in a production environment. The request for Azure to add the Access-Control-Allow-Private-Network: true header to the OPTIONS preflight response is a valid one and could potentially resolve the issue for many users with similar configurations. However, such changes would need to be addressed by the Azure development team.
    For now, it might be beneficial to keep an eye on updates from Azure regarding this issue or consider reaching out to Azure support for potential solutions or timelines for when this might be addressed.
