can you help reset an android phone?
mary ann willuhn 20 Reputation points
2026-02-24T03:20:00.8333333+00:00
I need some help resetting an Android phone.
I want some suggestions so I can receive and send messages
to friends and family?
AI answer
2026-02-24T03:20:05.7533333+00:00
To reset an Android phone, you can use the Company Portal app if your device is managed by an organization. Here are the steps to perform a factory reset:
  1. Open the Company Portal app on your managed device and sign in with your work or school account.
  2. Select DEVICES.
  3. Choose the device you want to reset.
  4. Select the menu button and then choose Factory Reset.
  5. Confirm by selecting RESET to start wiping the device.
This will erase all apps, settings, and personal data on the device.
If you want to send and receive messages to friends and family, ensure that your messaging app is set up correctly after the reset. You may need to reconfigure your messaging settings or reinstall any messaging apps you were using before the reset.
0 additional answers
