Azure function with a connection OPenAsync generates an exception
Patrick M 0 Reputation points
2026-02-24T01:38:09.6633333+00:00
Greetings Community,
The intent of my Azure C# function consists of accessing a Database hosted by a serverless Azure resource. With the use of the logger, I found out that it fails on the instruction
await connection.OpenAsync();
An exception is generated even though connection is not null. The following are few lines of StackTrace output:
2026-02-24T00:08:05 [Error] Exception Error fetching Message: Object reference not set to an instance of an object.
2026-02-24T00:08:05 [Error] Exception Error fetching Source: Microsoft.Data.SqlClient
2026-02-24T00:08:05 [Error] Exception Error fetching data: System.Collections.ListDictionaryInternal
2026-02-24T00:08:05 [Error] Exception Error fetching HelpLink:
2026-02-24T00:08:05 [Error] Exception Error fetching HResult: -2147467261
2026-02-24T00:08:05 [Error] Exception Error fetching TargetSite: System.Object LocalMachineRegistryValue(System.String, System.String)
This is my connection string:
Server=tcp:ucserver1.database.windows.net,1433;Database=Mydatabse;Persist Security Info=False;User ID=Myadmin;Password=MyPassword;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=60;ConnectRetryCount=2;ConnectRetryInterval=5
Regards,
Patrick M.
Azure Functions
Azure Functions
An Azure service that provides an event-driven serverless compute platform.
    2026-02-24T01:38:19.8633333+00:00
    The exception you are encountering when calling await connection.OpenAsync(); could be related to several factors, especially considering that you are working with a serverless Azure resource. Here are a few troubleshooting steps you can take:
    1. Check Connection String: Ensure that your connection string is correctly formatted and that all parameters are valid. Pay attention to the server name, database name, user ID, and password. Make sure that the database is accessible from your Azure Function.
    2. Network Issues: Since you are using a serverless Azure resource, check if there are any network restrictions or firewall rules that might be preventing your Azure Function from accessing the database. Ensure that the Azure Function has the necessary permissions to connect to the database.
    3. Connection Timeout: The error message indicates a potential timeout issue. You might want to increase the Connection Timeout in your connection string to allow more time for the connection to be established.
    4. Check for Null References: The stack trace mentions "Object reference not set to an instance of an object." This could indicate that some part of your code is trying to access a property or method on a null object. Ensure that all objects are properly instantiated before use.
    5. Azure Function Configuration: Verify that your Azure Function's configuration settings (like connection strings) are set correctly in the Azure portal.
    6. Logging: Utilize logging to capture more detailed information about the state of your application right before the connection attempt. This can help identify if any variables are not set as expected.
    If you continue to experience issues after checking these areas, consider creating a support ticket with Azure for more in-depth assistance.
