I need a Gamepass refresh
Verified. ✔ 0 Reputation points
2026-02-23T05:14:07.8366667+00:00
Theres a specific problem thats preventing me of play RANKED PLAY on Call of Duty BO7, it says I need a Gamepass refresh
Moved from: System Center Operation Manager
Windows for home | Other | Gaming
    2026-02-23T05:14:16.12+00:00
    To resolve the issue of needing a Game Pass refresh for playing Ranked Play on Call of Duty BO7, you may need to ensure that your Gaming Services and the Xbox App are up to date. Here are some steps you can follow:
    1. Update Gaming Services:
      • Launch PowerShell as an administrator and enter the command: get-appxpackage Microsoft.GamingServices | remove-AppxPackage -allusers.
      • Then, in the same PowerShell window, enter: start ms-windows-store://pdp/?productid=9MWPM2CQNLHN to reinstall Gaming Services.
    2. Update Xbox App:
      • Make sure you are in the RETAIL sandbox. If not, switch to RETAIL.
      • Launch PowerShell as an administrator and enter: get-appxpackage Microsoft.XboxApp | remove-AppxPackage -allusers.
      • Then, enter: start ms-windows-store://pdp/?productid=9mv0b5hzvk9z to reinstall the Xbox App.
    3. Restart your PC: Sometimes a simple restart can help resolve any lingering issues.
    After completing these steps, try launching the game again to see if the issue persists.
