Subject: OneNote Unexpectedly Changing Formatting Across Web and Desktop
Belinda L 0 Reputation points
2026-02-22T01:41:09.01+00:00
Hello OneNote Engineering Team,
I am reaching out regarding an issue where OneNote is unexpectedly changing the formatting of my notes, and the behavior occurs in both OneNote for the Web and the OneNote desktop application. Issue Summary Text formatting (such as spacing, alignment, indentation, or layout) changes automatically without user action. Edits made in the desktop app sometimes appear differently after syncing. The same formatting inconsistencies also appear when viewing or editing the same page in OneNote on the Web. This indicates that the issue is not isolated to a browser or device, but may be related to the OneNote service or sync engine. Troubleshooting Already Completed Tested in multiple browsers (Chrome / Edge). Tested on the OneNote desktop app. Restarted apps and cleared browser cache. Issue continues across both web and desktop versions. Request Could you please review this behavior? Since it occurs in multiple OneNote experiences, it may be a product‑level glitch. Any guidance or insight would be appreciated. Thank you for your assistance.
Microsoft 365 and Office | OneNote | For home | MacOS
    2026-02-22T01:41:21.37+00:00
    It sounds like you are experiencing synchronization issues with formatting in OneNote across both the web and desktop versions. This can happen due to various reasons, including differences in how each platform handles formatting and syncing. Here are a few points to consider:
    1. Sync Issues: Sometimes, the sync engine may not properly update changes made in one version to another, leading to formatting discrepancies.
    2. Feature Limitations: Certain advanced formatting features may not be fully supported in OneNote for the web compared to the desktop version. This can lead to unexpected changes when switching between platforms.
    3. Browser Compatibility: Although you have tested multiple browsers, it's important to ensure that your browser is fully updated and that any extensions or add-ons are not interfering with OneNote's functionality.
    4. Clearing Cache: Since you've cleared the browser cache, you might also consider checking for updates for the OneNote desktop app and ensuring that it is running the latest version.
    5. Contact Support: If the issue persists, it may be beneficial to reach out to Microsoft support for further assistance, as they can provide more specific troubleshooting steps or identify if it is a known issue.
    Given that you have already performed extensive troubleshooting, it may indeed be a product-level glitch that requires further investigation from the engineering team.
