How do I delete an Edge tab permantly
Chris Miller 5 Reputation points
2026-02-21T20:51:44.7533333+00:00
I have old, unused tabs at the top of every Edge page. How do I delete them permanently?
Microsoft Edge | Website issues | Windows 11
    2026-02-21T20:51:51.03+00:00
    To delete tabs in Microsoft Edge, you can simply close them by clicking the "X" on each tab you want to remove. However, if you are referring to removing old or unused tabs that appear in the jump list or as suggestions, you can manage this by clearing your browsing data.
    Here’s how to clear your browsing data, which will help in removing old tabs from suggestions:
    1. In Microsoft Edge, select Settings and more > Settings > Privacy, search, and services.
    2. Select Clear browsing data and then click on Choose what to clear.
    3. In the Time range dropdown, select a time range.
    4. Check the box for Browsing history and any other data you want to clear, then click the Clear now button.
    This will help in removing any old tabs from your browsing history and suggestions. If you want to prevent certain tabs from appearing in the future, ensure to manage your browsing habits accordingly.
