exam lab issue, white screen appearing( id :59312950)
Gireesh Hiremath 0 Reputation points
2026-02-20T10:44:29+00:00
I was getting error , not opening lab with exam credentials getting.
for certification exam "Microsoft Applied Skills: Create agents in Microsoft Copilot Studio"
Kindly resolve the issue, again i need to wait for 71 hrs.
    2026-02-20T10:45:09.73+00:00
    If you are encountering a blank white screen when trying to access your exam lab, a common solution is to open a new tab and navigate to https://portal.azure.com. This action often resolves the issue.
    If the problem persists, you may want to ensure that you are launching the lab in the correct environment and following any specific instructions provided in the exam materials. If you continue to experience issues, consider reaching out to Microsoft support for further assistance.
