Microsoft Edge, Edge Beta on android are not receiving fcm/web push notifications
Vinicius 35 Reputation points
2026-02-19T19:44:13.62+00:00
When you try to subscribe, the subscription URL that edge is generating is showing like this:
https://permanently-removed.invalid/fcm/send/abcx....
This is a critical issue and it used to work on the past. Works fine on any other android browser, also works fine on Edge windows 11.
Microsoft Edge | Website issues | Android
  1. Vishal Rajput 5 Reputation points
    2026-06-04T15:02:36.4033333+00:00
    The most recent
  2. paulr0511 48,365 Reputation points Independent Advisor
    2026-02-20T10:45:16.75+00:00
    If this is the case even on Beta and Dev and from the previous builds and versions. it is best to send a feedback from the Edge browser or cascade it from the link below for proper investigation and also for the team that is working on Edge to be made aware of this and hopefully it can be patched on the next or future update.
    https://techcommunity.microsoft.com/category/microsoftedgeinsider
  3. paulr0511 48,365 Reputation points Independent Advisor
    2026-02-19T20:34:31.8166667+00:00
    Hello, good day and thanks for your question. Is the same even on Edge Dev that you can download and install on the Play Store? If you will need for this to work on your end, the alternative at the time being is to downgrade Edge first from the previous version where this is working and then provide a feedback to the team that is working on Edge for this to get checked and get patched on the next update.
    https://microsoft-edge.en.uptodown.com/android/versions
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
  4. Keith Urban 0 Reputation points
    2026-08-13T21:38:36.25+00:00
    hello good evening, I want you bring all details together
