I have a tenant expired loop issue which is causing issues
gary callaghan 0 Reputation points
2026-02-19T12:21:42.96+00:00
My Microsoft account is stuck in an expired Azure AD tenant. I cannot leave the organization because the tenant is deleted or inaccessible. Azure AD authentication is defaulting to an invalid tenant .
    2026-02-19T12:21:52.2066667+00:00
    If your Microsoft account is stuck in an expired Azure AD tenant and you cannot leave the organization, you may need to follow specific recovery steps. Since the tenant is deleted or inaccessible, you will not be able to regain access through normal means. Here are some actions you can consider:
    1. Contact Microsoft Support: You should reach out to Microsoft support for assistance. They can help you with issues related to tenant access and may provide options for recovering your account.
    2. Identity Verification: Be prepared to go through identity verification processes as Microsoft may require this to confirm your ownership of the account.
    3. Check for Other Accounts: Ensure you are using the correct account to sign in. Sometimes, users have multiple accounts that may lead to confusion.
    4. Follow Recovery Procedures: If you are unable to sign in or access your tenant, you can submit a support request through the Microsoft 365 support page, selecting the option for sign-in issues.
    5. Documentation: Have any necessary documentation ready that may help prove your identity and ownership of the organization.
    Since your situation involves an inaccessible tenant, the recovery process may take some time, and you might need to be persistent in following up with support until the issue is resolved.
