will not recognize my serial number i try to add a device
jayrigs-5086 0 Reputation points
2026-02-16T19:32:04.3733333+00:00
time after time i have tried the different steps your people have suggested and continue to get the same result, nowhere... So here we are trying to solve the problem in the description above. When trying to add a device a.k.a. laptop the system set in place will 'continue to not recognize the serial number of the 2 in 1 laptop... i am not able to use the google play store to download apps, nor the Microsoft. Actually the Microsoft store will let me download them but they will not load and if it tries to it says there's an issue with no recourse of a fix of any kind. please and thank you i need your immediate attention to this reoccurring problem at your earliest convenience.
Windows for home | Windows 11 | Apps
    2026-02-16T19:32:45.4933333+00:00
    It seems you are experiencing issues with adding your device and using the Microsoft Store. Here are some troubleshooting steps you can try:
    1. Check Serial Number: Ensure that you are entering the correct serial number for your device. Sometimes, a simple typo can cause recognition issues.
    2. Restart Microsoft Store: Try restarting the Microsoft Store application. This can sometimes resolve temporary glitches.
    3. Check Internet Connection: Make sure your internet connection is stable, as this can affect downloads and updates.
    4. Microsoft Store Install Service: You can check the Microsoft Store Install Service. Press the Windows Key + S, type in services.msc, find the Microsoft Store Install Service, and ensure it is running. If it is disabled, set it to Automatic and start the service.
    5. Region Settings: Sometimes changing your region settings to the United States can help resolve issues with the Microsoft Store.
    6. VPN/Antivirus: If you have a third-party VPN or antivirus installed, try temporarily uninstalling it to see if it resolves the issue.
    If these steps do not help, you may need to consider reaching out to Microsoft support for further assistance.
