How to add same verified domain to 2 different tenants
Divyanshu 0 Reputation points
2026-02-16T17:08:52.2266667+00:00
We have 2 different Azure Tenats. One of them (Tenant A) have most of our users added with SAML setup (with Google workspace SSO), which requires us to add a verified domain same as the company's mail. (Eg: mycompany.com is the verified domain and the user SAML is registered with ******@mycompany.com). I would like to add the same domain to another Azure Tenant (Tenant B) and get it verified there as well due to production workloads running there. However it does not let me do that unless i removed the same verified domain from Tenant A. How do I keep the same verified domain in both the Azure Tenants.
    2026-02-16T17:09:00.9033333+00:00
    In Azure Active Directory, a domain can only be verified in a single tenant at a time. This means that if you have a verified domain (e.g., mycompany.com) in Tenant A, you cannot add the same domain to Tenant B without first removing it from Tenant A. Unfortunately, Azure does not support having the same verified domain across multiple tenants simultaneously.
    If you need to use the same domain for both tenants, you would have to consider alternative approaches, such as using subdomains (e.g., tenantA.mycompany.com and tenantB.mycompany.com) for each tenant or restructuring your domain verification strategy to accommodate both tenants without violating Azure's policies.
