If you're unable to access Safe Mode via msconfig and are locked out of your laptop, one option you might consider is performing a clean installation of Windows. This would allow you to set up the laptop from scratch, but it will erase all data on the device. If you have important files that you need to recover, you might want to try booting from a Windows installation media or a recovery drive to access your files before proceeding with a clean install.
Unfortunately, there are no specific methods mentioned in the provided context to bypass msconfig settings directly. If you can access the recovery options, you may also attempt to reset your PC or use the command prompt to troubleshoot further.
