Azure for Students subscription not showing up in actvn.edu.vn directory
NGUYỄN THẾ KỶ 0 Reputation points
2026-02-14T14:40:44.39+00:00
I am a student at "Hoc vien Ky thuat mat ma" (Vietnam). I have successfully activated the Azure for Students offer ($100 credit), but I am unable to see any subscriptions in my account.
Issue details:
  • When I log in to the Azure Portal, it says "No subscriptions found" in the actvn.edu.vn directory.
I have checked "All Directories" but cannot find the one containing my $100 credit.
I also tried using Azure Storage Explorer, but the subscription list is empty there as well.
I signed up using my school email: [Dán email actvn.edu.vn của bạn vào đây]
What I've tried:
Switching directories in the Portal.
Logging in using an Incognito/Private window.
Re-verifying my academic status (it says I've already redeemed the offer).
Could you please help me locate my subscription or move it to my home tenant?
Thank you!Hello,
Issue details:
What I've tried:
Thank you!
Azure
Azure
A cloud computing platform and infrastructure for building, deploying and managing applications and services through a worldwide network of Microsoft-managed datacenters.
    2026-02-14T14:41:25.4433333+00:00
    It seems you are encountering a common issue where your Azure for Students subscription is not showing up in the Azure Portal. Here are a few steps you can take to troubleshoot this problem:
    1. Check Directory Selection: Ensure that you have selected the correct Azure directory. Sometimes, the subscription may be associated with a different directory. You can switch directories by selecting your account at the top right of the Azure Portal and choosing the appropriate directory.
    2. Permissions: Make sure your account has sufficient permissions. If you are not the owner of the directory, you might need to have the Owner role assigned to your account to view subscriptions.
    3. Contact Support: If you have verified that you are in the correct directory and still cannot see your subscription, it may be beneficial to contact Azure support for assistance. They can help you locate your subscription or address any account flags that may be preventing it from appearing.
    4. Check for Account Flags: In some cases, account flags can prevent subscriptions from being created or displayed. If you suspect this might be the case, reaching out to Azure support will be essential.
    If you continue to experience issues after trying these steps, creating a support request may be the best course of action to resolve the problem.
