Entra ID and MDM removal/unenrollment
David Adamczyk 5 Reputation points
2026-02-14T00:11:44.4+00:00
How do you get yourself removed as a tenant in Microsoft Entra when you are part of an organization of which you have zero knowledge which organization it is? There is no indication when I log into my Microsoft account as a normal consumer and I have no access or rights because I am not an administrator in this anonymous organization. The only way I can try to get access is by manipulating URLs with active API tokens which is limited.
Is it possible to get your wiped data back after whoever has the controller decides to obliterate any accounts associated with your email? Do they need to provide any justification for destroying someone's personal and irreplaceable data? Is anyone even at the controller or did my data get wiped by Intune's automation? Is there any support for a human being that has been labeled a business. I have been stuck this way for at least a year and after many attempts for a solution has led nowhere. Quickly escalating to the loss of my personal accounts, phone, laptop, albums, money and professional reputation now about 7-8 months later since I last contacted Microsoft.
    2026-02-14T00:11:56.9233333+00:00
    If you are part of an organization in Microsoft Entra and wish to remove yourself as a tenant but lack administrative access, your options may be limited. Typically, users in unmanaged organizations can close their accounts independently, but if you are part of a managed organization, you would need to contact an administrator for assistance. Unfortunately, if you do not know which organization it is or cannot identify it, this complicates the process significantly.
    Regarding the recovery of wiped data, once an account is closed and personal data is removed, it is generally irreversible. Organizations are typically required to follow data protection regulations, which may include justifications for data deletion, but the specifics can vary. If your data has been wiped by automation tools like Intune, it may not be recoverable unless there are backups or other recovery measures in place.
    For support, it may be beneficial to reach out to Microsoft support directly, explaining your situation in detail. They may be able to provide guidance or escalate your issue to someone who can assist you further.
