It sounds like your microphone is not being recognized by your computer, even though the headphone speakers are functioning properly. Here are a few troubleshooting steps you can try:
- Check Connections: Ensure that the headphone jack is fully inserted into the audio port. Sometimes a loose connection can cause the microphone to not work.
- Device Settings: Go to your computer's sound settings and check if the microphone is enabled. You can access this by right-clicking the sound icon in the taskbar and selecting "Sounds" or "Sound settings". Make sure the correct input device is selected.
- Update Drivers: Ensure that your audio drivers are up to date. You can do this through the Device Manager by expanding the "Audio inputs and outputs" section and checking for driver updates.
- Test on Another Device: If possible, test your Beats headphones with a different device to see if the microphone works there. This will help determine if the issue is with the headphones or your computer.
- External Microphone: If the above steps do not resolve the issue, you might consider using an external microphone as an alternative solution.
If the problem persists after trying these steps, it may be worth looking into getting a new external microphone.
