Desperate for Help: Access Issues with Draft Site on SharePoint on my work
Estela Garcia 0 Reputation points
2026-02-12T00:16:11.8366667+00:00
Hello, community!
I really need your help. I have been working hard on a site in SharePoint, using Microsoft 365 for Business, which is currently in draft mode, and to my frustration, I can no longer access it. After months of dedication and effort, I feel completely powerless in this situation.
When I try to click on the site link, I am redirected to a different page, and to make matters worse, an irrelevant file starts downloading automatically. This is extremely frustrating for me, as the site was almost ready to be launched, and now it feels like all my work is at stake.
Here are the details of the situation:
  • Site Link: Accessing the link I used previously simply doesn’t work anymore.
  • Redirection: When I click, I’m taken to a completely different page.
  • Automatic Download: A file unrelated to the site is being downloaded to my computer.
  • Site Status: Everything was finalized and ready for publication, but now I feel out of options.
If anyone has experienced something similar or has any idea how I can resolve this issue, I would be eternally grateful. I’m desperate for a solution, and any help would be very much appreciated!
Thank you so much for your attention!
Windows for business | Windows 365 Enterprise
    2026-02-12T00:16:23.7833333+00:00
    It sounds like you're experiencing significant issues accessing your draft SharePoint site. Here are some steps you can take to troubleshoot the problem:
    1. Check Permissions: Ensure that you have the appropriate permissions to access the site. If your permissions have changed, you may need to contact your SharePoint administrator to regain access.
    2. Check for Site Deletion or Changes: Sometimes, sites can be deleted or moved. If you suspect this might be the case, check with your SharePoint administrator to see if the site is still available or if it has been renamed.
    3. Clear Browser Cache: Sometimes, browser cache issues can cause redirection problems. Try clearing your browser's cache and cookies, then attempt to access the site again.
    4. Access via Different Browser or Device: Try accessing the site using a different web browser or device to rule out any browser-specific issues.
    5. Check for Automatic Downloads: The automatic download of an unrelated file could indicate a misconfiguration or a potential security issue. Ensure that your browser settings are correct and that there are no extensions causing this behavior.
    6. Contact Support: If none of the above steps work, consider reaching out to Microsoft support for further assistance, especially since this issue involves a business account.
    Taking these steps should help you identify the issue and hopefully regain access to your draft site.
