A Microsoft file hosting and synchronization service.
To scan a document and open it in Immersive Reader after Microsoft Lens has been retired, you can follow these steps:
- Scan the Document: Use your device to scan the document using the new suggested method, which is to save it directly into OneDrive. This will typically save the document as a PDF or JPG.
- Convert the Document: Since Immersive Reader does not support opening PDFs or JPGs directly, you will need to convert the scanned document into a format that Immersive Reader can process. This can be done by opening the PDF in Microsoft Word, which will convert the document into an editable Word format.
- Open in Immersive Reader: Once the document is in Word format, you can then use Immersive Reader to access the text-to-speech features and other reading accommodations.
While this process may seem convoluted, it is currently the method available to ensure that students can still access the benefits of Immersive Reader after the retirement of Microsoft Lens. It is understandable that this change can be frustrating, especially for those who rely on these tools for support in reading disabilities.
