installed but 365 not working
Colleen Clark 0 Reputation points
2026-02-03T23:45:36.98+00:00
I installed the microsoft 365 but it is not working on my PC
Microsoft 365 and Office | Install, redeem, activate | For home | MacOS
    2026-02-03T23:45:44.4833333+00:00
    If Microsoft 365 is not working on your PC after installation, you can try the following troubleshooting steps:
    1. Check System Requirements: Ensure that your computer meets the system requirements for Microsoft 365.
    2. Repair Office: You can attempt to repair your Office installation. Go to "Apps & Features" in your settings, find Microsoft 365, and select the repair option.
    3. Uninstall and Reinstall: If the repair does not work, consider uninstalling Microsoft 365 completely using the Microsoft 365 Uninstall troubleshooter, then reinstall it.
    4. Check for Updates: Make sure that your version of Windows is up to date, as compatibility issues can arise from outdated software.
    5. Permissions: Ensure that you have the necessary permissions to run Microsoft 365 applications. Sometimes, security software can block access to certain files.
    6. Contact Support: If the issue persists, you may want to reach out to Microsoft Support for further assistance.
    These steps should help you resolve the issue with Microsoft 365 not functioning on your PC.
  2. Ferdinand Nanalig 32,835 Reputation points Independent Advisor
    2026-02-04T00:18:07.4833333+00:00
    Hi! Let me help you with this issue.
    Please let me know what kind of error you are getting.
    Thanks!
