Error code 0xA00F4243 Camera reserved by another app
Moshe Newman 30 Reputation points
2026-02-02T15:36:23.5033333+00:00
I am unable to use my laptop camera with Zoom
Troubleshoot Camera App error code 0xA00F4243
<Moved from: Windows for business/Windows Client for IT Pros/Devices and deployment/System management components>>
Windows for home | Other | Apps
    2026-02-02T15:36:33.76+00:00
    The error code 0xA00F4243 indicates that the camera is reserved by another application, which prevents you from using it in Zoom or any other application. Here are some steps you can take to troubleshoot this issue:
    1. Close Other Applications: Ensure that no other applications are using the camera. This includes video conferencing apps, camera apps, or any software that might access the camera.
    2. Restart Your Device: Sometimes, a simple restart can resolve conflicts with hardware resources, including the camera.
    3. Check Camera Privacy Settings: Go to Settings > Privacy & Security > Camera and ensure that camera access is enabled for the apps you want to use, including Zoom.
    4. Update Camera Drivers: Ensure that your camera drivers are up to date. You can do this through the Device Manager by finding your camera under "Imaging devices," right-clicking it, and selecting "Update driver."
    5. Use the Camera App: Open the built-in Camera app to check if the camera works there. If it doesn't, there may be a hardware issue or a driver issue.
    6. Check for Windows Updates: Make sure your Windows operating system is up to date, as updates can fix bugs and improve hardware compatibility.
    If the issue persists after trying these steps, you may need to look into more specific troubleshooting related to your device or contact support for further assistance.
  2. Harry Phan 30,960 Reputation points Independent Advisor
    2026-02-02T15:54:46.6066667+00:00
    Normally, code 0xA00F4243 comes directly from the Windows Camera app and usually indicates that the camera device cannot be initialized by the system. To fix it, first close any other apps that might be using the camera, like Teams or Skype. Then go to Settings > Privacy & Security > Camera and make sure Zoom has permission to use the device. If that doesn’t help, open Device Manager, right‑click your webcam under Cameras, and update or reinstall the driver. Finally, restart your laptop and test the Camera app, if it works there, Zoom will also be able to use it.
  3. muhammad daffa firdaus 0 Reputation points
    2026-09-10T18:49:01.1033333+00:00
    kamera whatsshap dan kamera saya trobel atau eror perbaiki semula
