To find your BitLocker recovery key, you can follow these steps:
- Microsoft Account: If you have linked your BitLocker recovery key to your Microsoft account, you can access it by visiting
https://myaccount.microsoft.com. From there, navigate to the Devices tab, select your Windows device, and choose the option to View BitLocker Keys. - Recovery Key ID: If you have the recovery key ID, you can use it to retrieve the recovery key through the Self-Service Portal if your organization has set it up. You would need to enter at least the first eight digits of the recovery key ID on the portal to obtain the full recovery key.
- USB Drive or Printed Copy: If you saved your recovery key to a USB drive or printed it, check those locations as well.
- Contact IT Support: If you are unable to find the recovery key through the above methods, you may need to contact your IT support or helpdesk for assistance.
Make sure to keep your recovery key secure, as it allows access to your encrypted drive.
