how to get heading numbers in Word to appear when formatting is hidden - they are there when formatting is shown
AVISAAH 20 Reputation points
2026-01-28T16:31:07.44+00:00
All our legal Word document templates are set up using heading styles for sections and subsections. We discovered that the header numbers appear when Show Formatting (the paragraph symbol) is turned on, but they disappear when Show Formatting is turned off, and they don't print out, either. This is a very new development and is affecting all of our legal document forms and templates. I can't figure out to how to fix it - it's obviously a software issue, since it's affecting all our documents.
Microsoft 365 and Office | Word | Other | Windows
Stefan Blom 352K Reputation points MVP Volunteer Moderator
2026-01-28T20:48:26.69+00:00
If heading numbers display when you display nonprinting marks, check if one or more heading numbers have been formatted as hidden text.
Note that with nonprinting marks displayed, you will see a dotted underline beneath text which is formatted as hidden.
Click a heading number to select it. Pressing Ctrl+Shift+H should remove the hidden format. The command is a toggle. See the screen shot below.
If this works, repeat for the other numbering levels / heading levels.
3 additional answers
  1. Charles Kenyon 170.8K Reputation points Volunteer Moderator
    2026-01-28T20:20:07.58+00:00
    Possible workaround: See if you can roll back to release 2511.
    Note that editing documents in Word online has also been reported to mess up automatic numbering.
    Here is my pdf on setting up Automatic numbering in Word. https://www.addbalance.com/usersguide/AutomaticNumbering.pdf
    This is a user-to-user support forum.
    Microsoft is not hearing about your problems from what you post here. You are discussing a problem with your fellow users here. We can give good advice about how to work with Word as it is and give suggestions for making it work properly.
    Designers and their supervisors do see feedback. (You will almost certainly not get a direct response to that feedback but they do see it.)
    Here is more about that:
    https://answers.microsoft.com/en-us/msoffice/forum/all/giving-feedback-on-microsoft-word-or-other/8df81a9b-84aa-46ef-bf88-24fb7fec96ba
    I suggest using the public feedback portal so other users can see your feedback, comment and vote. If you want, you can post the URL of your feedback with your question here to lead others with the same problem to your feedback. Be the “squeaky wheel” that gets fixed!
  2. Stefan Blom 352K Reputation points MVP Volunteer Moderator
    2026-01-29T10:35:27.8333333+00:00
    [...] I don't see my responses to the submitted answers displayed under them [---]
    Note that responses added immediately below the Question or below individual Answers are called Comments in the Q&A interface. Often, those are collapsed, so you won't see them unless you click the comment icon User's image to expand the view. Also, you have to make sure that you are signed in to Q&A; otherwise, Comments are not shown.
  3. Deleted
