Installation MS365 Business Standard auf dem gleichen Rechner wo ich Microsoft 365 privat habe.
Waltraud Hermann 20 Reputation points
2026-01-26T19:38:27.72+00:00
Gibt es Risiken, wenn ich auf dem gleichen Macbook wo ich derzeit noch ein privates MS365 Konto habe jetzt das Business Standard Konto installiere? Was passiert zum Beispiel mit One one? kann ich die Inhalte exportieren
Microsoft 365 and Office | OneNote | For business | MacOS
AI answer
2026-01-26T19:38:39.4833333+00:00
Installing Microsoft 365 Business Standard on the same MacBook where you currently have a personal Microsoft 365 account should not pose significant risks. Microsoft 365 allows users to have both personal and business accounts on the same device. However, there are a few considerations:
  1. Separate Profiles: It's advisable to use separate profiles for your personal and business accounts in applications like Outlook and OneNote. This helps keep your data organized and prevents any potential confusion between personal and business information.
  2. OneNote Content: Regarding OneNote, you can export your content from your personal account and import it into your business account if needed. This can be done by exporting your notebooks as a file and then importing them into the OneNote application associated with your business account.
  3. Data Management: Ensure that you manage your data carefully, especially if you are syncing content across both accounts. You may want to regularly back up important information to avoid any accidental loss.
Overall, as long as you manage the accounts properly, you should be able to use both without issues.
1 additional answer
    2026-01-27T01:12:40+00:00
    Hinweis: Diese Antwort wurde automatisch übersetzt. Daher kann es grammatikalische Fehler oder unbeholfene Ausdrücke enthalten.
    Lieber @Waltraud Hermann,
    Willkommen im Microsoft Q&A‑Forum!
    Ich kann sehen, dass der Q&A Assist deine erste Frage bereits geklärt hat: Es besteht kein Risiko, Microsoft 365 Business Standard auf demselben Mac wie dein persönliches Microsoft‑365‑Konto zu installieren. Beide Konten bleiben voneinander getrennt, und OneNote kann problemlos mit mehreren Konten gleichzeitig verwendet werden.
    In der Zwischenzeit möchte ich dir einige Hinweise zum Exportieren von OneNote‑Notizbüchern unter macOS geben. Hier sind die offiziellen Microsoft‑Supportartikel, die beide Methoden erklären:
    1.OneNote‑Notizbücher exportieren und importieren (vollständiger Notizbuch‑Export):
    • Microsoft unterstützt den Export eines vollständigen OneNote‑Notizbuchs, jedoch nur über OneNote im Web und nur für Notizbücher, die auf einem persönlichen OneDrive‑Konto gespeichert sind.
    • Notizbücher aus Geschäfts‑ oder Schulkonten (Microsoft 365) können auf diese Weise nicht exportiert werden.
    Bitte sehen Sie die Details in diesem Artikel ein: Exportieren und Importieren von OneNote-NotizbüchernUser's image
    2.Notizen als PDF in OneNote für Mac exportieren (nur Seiten oder Abschnitte):
    Wenn du OneNote für Mac verwendest, kann die App kein komplettes Notizbuch exportieren. Du kannst jedoch einzelne Seiten oder Abschnitte als PDF exportieren. Bitte sieh dir hierzu diesen Artikel an: Exportieren von Notizen als PDF-Datei in OneNote für Mac
    Hier eine Zusammenfassung für diesen Fall:
    • Export eines vollständigen Notizbuchs > Nur über OneNote Web möglich, und das Notizbuch muss auf persönlichem OneDrive gespeichert sein.
    • Export in der Mac-App > Es können nur Seiten oder Abschnitte als PDF exportiert werden, keine ganzen Notizbücher.
    • Geschäfts- oder Schul-Notizbücher (Microsoft 365) können nicht vollständig exportiert werden.
    • Wenn OneNote auf deinem Mac nicht mit OneDrive synchronisiert, kannst du über die Druckfunktion als PDF exportieren:
    • Gehe zu „Ablage“ > „Drucken“ > PDF-Menü unten links > „Als PDF sichern“ und wähle dann einen Speicherort. Andernfalls musst du möglicherweise die Inhalte manuell per Kopieren/Einfügen sichern.
    Ich hoffe, diese Informationen geben dir einen guten Überblick über die Funktion. Ich wünsche dir einen angenehmen Tag!
    Hinweis: Bitte folgen Sie den Schritten in unserer Dokumentation, um E-Mail-Benachrichtigungen zu aktivieren, falls Sie die zugehörige E-Mail-Benachrichtigung für diesen Thread erhalten möchten.
