Trackpad not working after sleeping laptop
Skye F 20 Reputation points
2026-01-26T04:28:21.8133333+00:00
Issue:​ Trackpad becomes completely unresponsive after the laptop resumes from sleep. The issue persists regardless of the Fn+F8 toggle state (enable/disable icon appears normal). A full system restart (2-3 times) is required to restore functionality.
Context:​ This occurs frequently while using an external mouse (both Bluetooth and USB). The problem makes the laptop unusable without an external mouse.
EDITION: Windows 11 Pro
VERSION: 25H2
OS BUILD: 26200.7623
CPU: 13th Gen Intel(R) Core(TM) i5-13500H (2.60 GHz)
RAM: 16GB
LAPTOP MANUFACTURER: LENOVO
Windows for home | Windows 11 | Sleep and Power on, off
DYARI BARHAM 37,661 Reputation points Independent Advisor
2026-01-26T05:38:06.23+00:00
Thank you for sharing the screenshot.
Yes, based on the screenshot (I2C HID Device – “This device cannot start (Code 10)”), this is directly related to the touchpad not working. In most cases, it can be fixed by reinstalling or updating the correct driver.
Right-click on the I2C HID Device > Uninstall device > Restart the computer. Windows should reinstall the driver automatically after a restart.
2 additional answers
  1. DYARI BARHAM 37,661 Reputation points Independent Advisor
    2026-01-26T05:14:22.8366667+00:00
    Hi ,
    I'm Dyari. Thanks for reaching out. I will be happy to assist you in this regard.
    Kindly right-click Start > Device Manager > Expand Human Interface Devices > Open I2C HID Device and also Touchpad device if listed > Double click on it and go to Power Management > Uncheck "Allow the computer to turn off this device to save power" > Repeat for any device related to touchpad/mouse >Restart once and test.
    It is also recommended to download and install the latest drivers for your computer only from the manufacturer's support page.
    Please let me know if you need further assistance.
  2. Ashish D 0 Reputation points
    2026-07-09T04:42:30.35+00:00
    Does the problem persist? Answer so that I can help.
