Microsoft edge doing searches and looking up results automatically.
attiya habib 0 Reputation points
2026-01-24T05:49:44.7+00:00
The issue I'm facing is that Microsoft Edge is doing searches automatically without my consent. It happens when I open Edge, search for something, and it even shows the result to my search, but the next second, it automatically starts to search and look up results for "smilehavendental in", which I have no connection to. The typing appears to be normal speed with seldom any human typing errors. I have no extension on my Laptop or Edge except for some save memory stuff---means no suspicious extension. I also did a quick virus scan, but still nothing. So what is this issue about, how to resolve it, and how to prevent it in the future? Thanks for the cooperation.
Microsoft Edge | Other | Windows 10
    2026-01-24T05:49:54.9+00:00
    It sounds like you might be experiencing an issue with Microsoft Edge where it is automatically performing searches without your input. Here are a few steps you can take to troubleshoot and potentially resolve this issue:
    1. Check for Malware: Even though you've done a virus scan, consider running a more comprehensive malware scan using a different tool, as some malware can evade detection.
    2. Reset Edge Settings: Resetting Microsoft Edge to its default settings can help resolve issues caused by misconfigurations. You can do this by going to Settings > Reset settings > Restore settings to their default values.
    3. Clear Browsing Data: Sometimes, corrupted cache or cookies can cause strange behavior. Clear your browsing data by going to Settings > Privacy, search, and services > Clear browsing data.
    4. Disable Hardware Acceleration: Go to Settings > System and performance and toggle off Use hardware acceleration when available. This can sometimes resolve performance issues.
    5. Check for Updates: Ensure that your Microsoft Edge is up to date. Go to Settings > About Microsoft Edge to check for updates.
    6. Create a New User Profile: Sometimes, user profiles can become corrupted. Try creating a new user profile in Edge to see if the issue persists.
    7. Review Extensions: Although you mentioned you have no suspicious extensions, double-check that there are no extensions enabled that could be causing this behavior. Go to Settings > Extensions to review them.
    If the issue continues after trying these steps, you may want to consider reinstalling Microsoft Edge or reaching out to Microsoft support for further assistance.
